Starts and then shuts off after it kicks down right after starting. If you put one foot on gas and one on break it will stay runing. If you take foot off gas at stop will shut down. Could be a fule filter are more?
The engine starts easily but as soon as the accelerator pedal is pressed,the running goes offThe engine starts easily but as soon as the accelerator pedal is pressed,the running goes off
You can't post conmments that contain an email address.
I would check for proper fuel pressure. Sounds like your pump might be on its way out. For a TBI engine you should have around 10PSI at the throttle body.
This could be many things, start by retrieving any codes the emission system may have thrown, may need a tune up, may have jumped timing, may have a head gasket blown.
Turn off all your accesories and turn the key forward, but dont start it. You should hear the pump kick on for 2-3 seconds. Prime the system a few times then start it. This will narrow your diagnosis
ok i have a 1998 durango with the 5.2L 318 engine. had trouble with a bad cell in my battery. I went out bought an optima red top battery for it 800cca. put it in and had same trouble. No start without putting foot on gas. wouldn't stay running without holding foot on gas. CPU has to relearn it's programming once you unplug it for long periods of time. mine was without power for about 2-3 weeks till i got new battery. Start with this.. first check under air filter make sure a squirrel hasn't made a mess under your air filter and it's clogging the air intake. Then pull off the lid to your injector cover ( the screw down lid coming from the air box ( with air filter in it) to "carb") make sure all your cables move freely. put that all back together and close hood. Start truck with foot slightly on gas pedal to get started. keep it at about 1k to 1500 rpm for about 1-2 minutes. Rev motor to about 2500rpm and let it die out if it will. Get out lock doors with key fob if you have it. if not make sure to lock doors. ( trust me it worked for me) let sit for 5 minutes. come back out and unlock door and relock door 3 times with fob ( if you have it ) or key if you don't have a fob. Then unlock it with the key and enter vehicle. Start truck as before and keep it around 1k to 1500 rpm again for about 30 seconds rev it up and should keep running. Mine did. I think the iac was stuck from sitting and has now since loosened up. Good luck hope ti works for you.
If you were driving a Ford, I would say your throttle position sensor is bad or out of adjustment. This device should be around the throttle plate/throttle cable area.
Hello You will have to reset your fuel pump switch located passenger side right foot kick panel when you press it it should stay down if this does not work your probably looking at a fuel pump not working.
