SOURCE: SGH J600 JAVA ERROR!
I had the same problem. It was solved by making a new jad file with jadmaker and using that instead of the original jad file.
SOURCE: driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
In most cases the printer/scanner driver software can have errors while being in use or is shut down. So to reset remove your printer/scanner from the PC and uninstall the driver software. Now reinstall the driver software and then connect the Printer/Scanner ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now a alignment test must be done with a print out and a scan as it will seet to optimum settings.
If there is no response then the scanner has errors in the optical system/motherboard and will need an estimation.
Thank you for using Fixya
