Alpine CHM-S620 6-Disc CD Changer Logo
Question about Alpine CHM-S620 6-Disc CD Changer
Hello i have a bmw with a 6 cd auto changer fitted in the boot i think its a factory installed alpine , but it skips when the car goes over a small bump . ive been told the laser has been damaged by copied cd's can it be repaired ??
Posted by stuart_presc on
Sergey
    New Friend:
    Problem Solver:
  • 13 Answers
Copied cd's can't damage this part. The pick-up of this changer can't be repaired, it should be replaced as a whole part. Also please check a position anti-shock system (two mechanical parts on sides of the unit). It must be set in the same position as the changer is installed.
Posted on Jul 13, 2011
1helpful
Where do rover fit the cd multi changer in a rover 75 as mines missing.
the 6 cd multichanger fits either in the glove box or on brackets in the boot, model is alpine cmh s630comes with fixings, all other interfaces are inside boot, behind bumper under hard black plastic cover. hope this helps
I'm trying to locate a cd changer cartridge for my alpine cd changer in my 2000 bmw 528i.. hopefully locally
whats the model number of the alpine changer??? they usually sell for about $40-49 plus shipping. where are you located??
I have a 2000 BMW 528i and an Alpine CHA-614 CD changer. I bought the Soundgate interface and hooked everything up per the instructions. The changer has power since I can remove the cartridge, but doesn't...
it could be the interface is bad. i just tested on with brand new changer..and it did the exact same thing yours did. its either the interface or the factory radio is bad. i would think the interface.
2answers
6 CD Multichanger
Hello There.
My guess would be that your sat nav was retro fitted, i'e not factory fitted. Who ever fitted it didn't use the correct wiring harness. It seems they may have used a wiring harness which didn't have the connection for a CD changer.
If you want to get this fixed you will need to replace the wiring harness which means stripping out the entire interior of your car, i.e seats, carpet, door panel. or you can live with the single CD which works.
If my answer has solved your problem, please rate me on fixya.
Thank you
1helpful
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
3helpful
3answers
Factory installed Alpine 6 CD Changer- cd magazine (for 1998 BMW 528i E39)
Hi , seen lots of these.
whats happend is the Tray that the disc sits in has jammed halfway in.
in most cases giving the mag a swift tap (hard tap) with the haddle of a screw driver , while pushing the eject button normally is just enough to dislodge the mag.
otherwise its a repair job.
were do you live Alison?
Regards
Mark
www.blueice-electronics.co.uk
Discs are skipping in my changer
cds skip irrespective of their positions as the reading lens is the same for all.
you can do the following
1)this seems to be a SERVICING problem with dust playing the spoilsport.
OR
2)buy a new disc (scratchless) , play it in all positions and com pare.
if it skips in all positions, call an electronic engineer who will replace /repair the delay circuit.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
