OKI B4350n Laser Printer Logo
Posted on Jul 12, 2011
Hi, the C3450N-printer is permanently flashing (all 3 LEDs). "fatal internal error". Reading the error code gives 980 (100-110-000-000). What's wrong? rgds Kalle
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
1helpful
2answers
Fatal Error 121
My OKI C5800LDN printer displayed the Service 121 error last night. After reading the previous solutions, and trying them with no success, I followed the instructions in the service manual, and removed the High Voltage Power Supply Board. There are four cables that plug into the board, the rest of the electrical connections are made between spring loaded fingers that make contact directly with the board when snapped into place. I used a rubber eraser to carefully polish each one of the fingers and their connections points on the circuit board. I re-installed the board, and the error is gone.
1helpful
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
I just replaced the fuser unit in my Okidata 5200 and it will print for awhile and then stop with a fatal error #177. How do I fix this?
lift your top cover up and check the ribbon cables to the black leds (4) under the cover 2 on each led, these have been known to be loose and cause those fatal error codes
New fuser - do I need to reset
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
3answers
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Greetings,
FATAL ERROR CODE : unit is unable to perform requested operation
No reset or fix for that problem.
New camcorder or repair - get a quote for repair and compare price for a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
8helpful
4answers
Hp1200 error codes
when all light is on printer has a fatal error ( Problem with scanner section or Fuser section)
Secondary error pls tell me is it blinking
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
