Question about Fisher Price I Can Play Piano System
Piano lights up but will not stay on when i let off of the power button.
Posted by riley7375 on
poiboy630
There's an on/off switch on the bottom of the unit by the battery compartment. make sure this switch is on, then turn on the power button on the piano.
Posted on Sep 03, 2011
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
My piano won't boot up.
Who manufactures your piano? Call them.
Aug 10, 2017 | Casio Celviano AP-620 88-Key Digital Piano...
How to reset the Privia Px-110 back to factory setting
Try this
1. Turn off the digital piano
2. While holding down both the (TONE) and (FUNCTION) buttons, press the (POWER) button
Nov 17, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
I have a Yamaha Clavinova clp 360; it no longer turns on.
Paul, inside of the Clavinpva at the rear where the power cable connects to the board. there is a 124 volt 1.25 amp fuse. the old type that is a glass cylinder with silver ends. it's an easy fix and will cost about $3.00 for a pack of four. You have to9 take out all of the screws on the bottom of the piano in order for the top to slide off, but you can do it in about 15 minutes!
Dec 30, 2012 | Yamaha Full-Size Keyboard
Kurzweil Sp2x
It may be the line current at those venues.
If you have a lightweight switchmode supply, you can try adding some ferrites to the power cord from the wall. but you almost need to switch to an older style heavy transformer supply for reliablity. It is my guess there is a great deal of noise on the supply current at those vehues you have had problems at. That noise does not play well with switchmode.
Feb 04, 2012 | Kurzweil Music
Need repairs on Technics SX-PX103-M Model.
Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
Jan 19, 2012 | Music
I have a Williams Encore Digital piano. When I power up there is no sound. Upon power up there are 8 small rectangle on the LCD screen. 7 red light are lit. They are the 4 lights above the "user...
Holding the page up and down buttons while powering on supposedly resets it. I have no sound except demos, but no lights showing like yours, and williams tech support said to reset that way but it didn't seem to do anything. Good luck hope this helps!
Jun 27, 2011 | Williams Encore Digital Piano
Piano nova digital piano wont switch on. Green light is on on adapter but power switch does nothing.
Verify the cord from the adapter to the piano is not broken (common occurance) using a voltmeter at the connector.
Then verify the connnector is seated in the piano.
Apr 24, 2010 | Music
Casio Privia Px-120 88 key digital piano frozed.
Not sure that this is the right answer.
But it works very well with other electrinic devices.
When you turn off the unit it resets itself.
ie: the parser code program on the IC (Integreated Chip) defaults to the base program
upon power up.
This problem commonly occurs from a voltage drop at a standard household outlet.
It can occur from other high draw electrical items that are on the same circuit being turned
on while your playing your keyboard.
So stay away from extension cords as these increase electrical resistance.
ie: you dont get enough power for the device.
Another thing that can cause this is power strips.
I know we all use these for certain items but they can wreak havok on electronic
components by not being able to supply enough power.
Best that if something like this happens to plug the item directly into an outlet.
And make sure that Momma's microwave isn't gonna kick in anytime soon.
Hope this info helps.
Bobby
Jan 11, 2009 | Casio Portable Keyboard Touch Sensitive...
Ensoniq MR-61 keyboard
reset that piano by giving it 20 min with power!!
plz aret this post
Aug 21, 2008 | Computers & Internet
Fisher Price I Can Play Piano System Logo
501 people viewed this question
Top Fisher Price Toys Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
