AEG Lavamat 72640 Front Load Washer Logo
Question about AEG Lavamat 72640 Front Load Washer
Lavamat 72950-a3 could you advise me how to get spin only programe
Posted by scottlesjan on
Anonymous
    Brigadier General:
  • 6,277 Answers
Please see your other posting ;-0)
John C
Posted on Jul 12, 2011
Hi please advise.my aeg 110 lavamat does not switch on.completely dead'
Lavamat 110 doesn't exist. Maybe it's a lavamat 1100;1105 or similiar...
Dado
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
The washing process stops after about 12 minutes at any program and the green door light is on but water in the drum.
it looks like your heating element are dead. But Im not sure.
Does drum is spinning?Does it pumps water then you set in on "drain" program?
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
2answers
Can't print A3
Does your program allow for custom size? If so enter 297 and 420mm if in metric
The printer dialogue box may need to be advised of this size also
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
No manual Lavamat 625 Senstronic
Still looking Lizziehmp?
1 - wash with pre-wash
2 - Quickwash
3 - soft rinse
4 - long spin (4 + woolmark -- short spin for wool)
5 - extre pre-wash / soak program
6 - pump-out
it is actually more complicated as each number above is further modified by pressing combinations of buttons. (see for example 4 above)
E - economy
1/2 - for small loads
funny V symbol - variomatic spin
Leave some contact, I could get you a copy of instruction card
Happy washing.
Voitek
(Warszawa, Poland)
How to re-fit front rubber seal on Lavamat
The seal is mounted to the outertub with a big spring, an on the frint with a plastic ring. Not very easy.
Top AEG Washing Machines Experts
john h
W.L.
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
