Question about Dell OptiPlex 170L PC Desktop
How to boot from a USB CD/DVD ROM MY System is Dell Optiplex 170L Thanking in advance
Posted by shahid_ma107 on
John Lennard Lozada
  • 220 Answers
If you want to boot from a external cd/dvd rom here's what to do.
  1. Connect your USB CD/DVD ROM to your computer.
  2. After connecting, you must start from boot up. so Reboot your computer.
  3. You must go to your bios settings, so during boot, press DELETE or if it doesn't work reboot again and try F2.
  4. Now once on the bios settings, search for the boot device, or boot priority.
  5. You must make your USB CD/DVD ROM as First boot, or just place it at the top of the list.
  6. You can adjust the position by pressing (-)minus and (+)plus signs in your keyboard.
  7. Now once the USB CD/DVD ROM is at the top. press F10 to save the changes and click Yes.
  8. And that's it. Your PC will now boot from the USB CD/DVD ROM.
Goodluck, Hope my solution will help, Please give some feedback regarding my solution.
Thank you very much for using Fixya! Have a Great Day!
Posted on Jul 12, 2011
  • ranabdrang Jul 23, 2011
    in the BIOS setting it doesn't show the USB CD/DVD ROM in the boot sequence. so how can i add this??
  • WES2859 Jul 11, 2012
    First of all... ALWAYS START WITH A KNOWN GOOD when troubleshooting and work from there!. I CAN'T EMPHASIZE THAT ENOUGH!
    What this means is make sure your USB device is bootable on another machine. Typically I have found anomalies in system bios (personalities) configs that prevent USB booting from a KNOWN GOOD USB BOOTABLE device i.e. USB memstick / thumbdrive or External USB CDROM drive.
    Now regarding the DELL OPTIPLEX 170L BIOS Ver. A07 I've had to fiddle a bit.
    Current installed hardware:
    No FLOPPY drive installed
    QTY. 1 - 320 GB SATA on the "SATA Primary" channel (there's only 1 channel)
    QTY. 1- 40 GB IDE as Master on the Primary IDE channel
    QTY. 1 - IDE CDROM as Master on the Secondary IDE channel
    Note: These channels I'm referencing are actual hardware interfaces on the MB and they're labeled. Might need glasses & good flash light ;-)
    SO, 2 hard drives (1 SATA, 1 IDE) and a CDROM installed. And no Floppy.
    Here are the settings in my A07 bios that worked under "Drive Configuration"
    Diskette Drive A: "NOT INSTALLED"
    SATA PRIMARY: "HARDDRIVE" (the bios sees the SATA drive under it's "auto" config)
    PRIMARY MASTER DRIVE: "HARDDRIVE" (again, the bios sees the Primary IDE under "auto" config)
    PRIMARY SLAVE DRIVE: "OFF"
    SECONDARY MASTER DRIVE: "CDROM Device"
    SECONDARY SLAVE: "OFF"
    IDE UDMA DRIVE: "ON"
    Under "HARD DRIVE SEQUENCE"
    1= "USB DEVICE"
    2= "SYSTEM BIOS BOOT DEVICES"
    Under "BOOT SEQUENCE"
    1= IDE-CDROM DEVICE (HAS CHECK MARK FOR ENABLED)
    2= HARD-DISK DRIVE C: (HAS CHECK MARK FOR ENABLED)
    USE THE SPACE BAR TO ENABLE/DISABLE TOGGLE.
    THE REST OF THE CONFIG IS DEFAULT
    I am able to boot & see both hard drives (on 2 different interfaces SATA & IDE) and the CDROM drive.
    Hope this helps.
How can i do bios recovery in dell optiplex 170L
You should take out CMOS battery and wait for some time, replace it and BIOS should be reset to factory condition
Nov 10, 2014 | Dell Optiplex 170L Dmc Pc - No OS - P4 3.0...
How to boot from a external dvd rom drive on a dell optiplex 3020
Anonymous,
You can plug your device into the USB PORT. Start the computer and press the F12 key. You will then see options that you can boot the system to. USB storage is one of the options.
The computer attempts to boot from the sequence of devices specified in this list:
Diskette drive
Internal HDD
USB Storage Device
CD/DVD/CD-RW Drive.
Onboard NIC
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 14, 2014 | Dell Computers & Internet
How can I clean the hard disc & re-install windows on my Dell Optiplex 170L computer?
Put the windows cd in the cd drive. Restart your computer while pressin Del or F2 to go to the system BIOS and go to Advanced BIOS settings and go to boot order or boot sequence, select Cd/Dvd to be the 1st device on the list. Hit F10 to exit. Your computer will restart and boot from the cd. On the first screen, just press enter. Then F8 to accept license agreement. Then you will press esc. Select the partition that you want to clean up! Select the first option (quick NTFS), then press F to start formating! Wait and follow the instructions on the screen.
Dec 13, 2011 | Computers & Internet
How can I use External USB DVD rom for Boot to dell optiplex GX260 series.
You have to change the boot settings in bios (hit F2 as you see the Dell Logo) and in the boot menu look for one that says boot from USB, or external CD drive, and move it to the top of the list so it will boot before the hard drive does.
Jul 23, 2011 | Dell OptiPlex GX260 PC Desktop
Cant start up because I need to reinstall, system32\hal.dll
try safemode by taping f8 in bot,
if you can get your hands on a windows cd you can reintall by pushing f12 when the first dell screen, then in the list boot from cd-rom
May 07, 2010 | Dell OptiPlex 170L PC Desktop
Hi, My Optiplex 170L BIOS has stopped recognizing my CD/DVD player ("Unit not installed"). The unit still functions in that the drawer opens and closes with the light flashing. I have downloaded and...
Ok this is commin.....
1 try a different CD ROM.
Or the mother board controler has dead.
Hopfully it's just the rom
PS...This asumeing you haven't installed another IDE device on the same ribbon cable
Feb 16, 2010 | Dell OptiPlex 170L PC Desktop
Booting XP
I would purchase an external cd rom drive and use it to boot the system.
Sep 18, 2009 | Dell OptiPlex SX260 (SX2607QV0521) PC...
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Nov 17, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex 170L PC Desktop Logo
1,962 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
