Sony KV-32S35 32" TV Logo
Question about Sony KV-32S35 32" TV
My sony t.v would not power - Sony KV-32S35 32" TV
Posted by benkaybabs on
Wale Sarumi KomputerSolution
  • Sony Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jul 12, 2011
Who has schematic or knows which power transistor has a Sony AC-64N power supply 6Volt-500 mA?
NO DEVICE STated fits a SONY what,
we now know its 1982 wall wart but no DEVICE known
and was hacked, by others, wow./
my wild guess is SONY radio, 1982, year is correct
device not known, and matters.
Where can I find a A1300319A Board. Because the tech took the board out, and said something wrong with the board.
customer care support SERVICE number+1-
-833'''272''''0777,,,,,,,,,,,call them
THIS SONY A-1300-319-A COMPLETE PC D BOARD IS DESIGNED TO WORK WITH SELECT SONYTELEVISIONS.
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Power light flashes but wont turn on I was told it is making a high piched sound frome the power supply and needs replacing. I want to replace it myself or rather my son will what part number do I need to...
It sounds like you have a short in your power supply. Sony have problems with these parts going out: http://www.partstore.com/Part/Sony/Sony/KV30HS510/Sony/Sony/670581001/New.aspx
but if you are not familiar with electronic repair you would have to look at your power supply and get the exact number off it to compare with these:http://www.partstore.com/SearchResults.aspx?q=Sony+kv30hs510+Power+supply&ctf=%5B2+TO+4%5D&ctfn=Parts
hope this helps
On the Sony DSC-H7 camera can you disable the auto power off? If not does the use of an external power supply disable it? Thanks
The auto power off function that operates if the camera is not used for about 3 minutes, when operating on battery power, cannot be deactivated.
When using the camera the camera powered from the Sony AC-LS5 AC mains adapter, or with the Sony DCC-L1, DC power adapter, the camera auto power function is deactivated whilst the camera is connected to the power supply.
No power to my Sony Vaio RX380ds. Already replaced power supply.
disconnect the power adoptor and remove the battery and hold down the power button for 10sec and than connect everything back again and that should work
Sony vaio problem
the Hum is coming from a fan inside the laptop.
if sony had already changed the power supply and the problem pressist that means its not a problem with the power supply it is a problem with the prossecor fan.
check i fu can clean it or even see if the computer get so slow while the ham strats cuz it is trying to cool it self uising the RAFm
plz rate this post.
SONY DCR-TRV20
Yes, Power supply/ charger can be one reason. You can get ACL-15A from following Sony link.
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
