Question about Apple iPhone 3G Black Smartphone
My iphone 3 wont just turn on after it was overcharged for probably 8 hours. From some of the discussions i read, there was a solution but its for iphone with Apple logo, but mine doesn't have any logo at all and it is just off.. Please help.. Thanks..
Posted by Swt_cheeks on
5 Related Answers
Anonymous
SOURCE: iphone reset
Ok I have this problem, rite now and i just cme off of the phone with an apple support technician. Ok when ur logo is up...hold down the home and sleep buttton until the apple logo dissapears...now ur phone should be off. Make sure ur iphone is not connected to usb so far...wait 2 minutes and open itunes on ur comp, and plug one end of the usb cable into your computer...now, hold down the home button DO NOT LET GO, and while holding it down, plug in the usb cable into your iphone and wait for itunes to say that it has discovered an iphone in recovery mode,after u see it in itunes, let go of home button and click ok. Now, click restore and you are on your way to a working iphone again :D if any more problems email me at [email protected], so i can give you further information.
Posted on May 28, 2009
feelfemi009
femi john
  • 277 Answers
SOURCE: Freezing iphone 3g
if yopu have too much files on the memory pls delete some,if it persist just flash in new memory and the hanging will be detected and it will be corrected.
Posted on Jul 17, 2009
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: my iphone 2g no start up only apple logo i try to reset but still
I had this same thing happen. My eventual fix was to upgrade the iphone to OS 3.0 and then use redsn0w to re-jailbreak it. It took me many hours to figure this out, but I don't guarantee that it will work for everyone. It's just what worked for me.
Since then, I have updated Cydia again, and it seems to work fine now. It may have been crossing with other jailbreak apps I had on there when I updated Cydia. This time I did it right away after the restore.
If you need to hard reboot then pleas follow the steps below:
Hold power and home buttons for 20 seconds for the reboot. Then hold them again for 10 seconds, after which you let go of the power and keep holding the home button for another 10 seconds.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 20, 2009
Anonymous
SOURCE: my iphone wont go past the apple logo
hi juli this is glady even i faced the same prob in my i phone to so download a new firmware from apple site nd then switch off ur cell while conectd to ur pc then switch on through ur apple pc suite upgrde ur phone through the i tunes o give the path nd see or better to go to youtube for more crystal clear info bye
Joed911
JDTec
  • 4338 Answers
SOURCE: why wont my iphone turn on???????? please help!!!!
Try these resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 24, 2009
The book wont come on even after charging for 6 hr help??
Search Results
    Amazon.com: Customer Discussions: Kindle paperwhite won't turn on
    www.amazon.com/forum/kindle?_encoding...
    Amazon.com, Inc.Nov 6, 2013 - If the kindle is idle for several minutes it turns off automatically but then I can't turn it back on again (even after rebooting and waiting 5 minutes). My Kindle paperwhite got stuck ...
    May 17, 2013
    Frozen Kindle Paperwhite
    Jan 8, 2013
    My Kindle won't charge
    Jan 3, 2013
    My kindle won't turn on
    Sep 10, 2012
    More results from www.amazon.com
    Amazon.co.uk: Customer Discussions: Kindle won't turn on. Anyone help?
    www.amazon.co.uk/forum/kindle?_encoding...
    Amazon.com, Inc.
Dec 20, 2015 | Amazon Kindle Paperwhite WiFi
After using quick my Ford Exploere 2004 car wont start anti thft light blinking
The battery reset protocol usually means the 8 turns routine using the original keys with key fob transponders
Turning the key and moving the shift from park to drive and back again has helped some people
More information here
https://www.cargurus.com/Cars/Discussion-c112_ds558688
Aug 16, 2017 | Ford Explorer Cars & Trucks
Battery only holds for 3 hours despite following all instructions. that's 3 hours of reading time with wifi turned off
I would replace the battery then, if the battery isn't removable then you could buy a used device on eBay for $30.
Dec 14, 2013 | Nextbook Premium 8 Se Android
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
For how long do you charge a 9.6V NiMH Battery Pack 700 mAh? It says don't overcharge, but can't find any info to instruct what overcharging is!! It goes to a remote control car made by Maisto. It is a...
There are too many unknown variables in this. One is the charger that you are using. Two is the amount of charge in the battery when you charge it. These are things you must know. However with new chargers you can be sure they wont over charge the battery. If you are still worried about it, put it on charge and check it every hour or so and don't go past 8 hours.
Oct 22, 2017 | Maisto Toys
My iphone wont turn on past the silver apple logo.
Open up iTunes, connect the iPhone. Hold down the power button for 3 seconds, hold both power button and home button for 10 seconds, release power button while still holding down the home button. This puts your iDevice into DFU mode, so it can be restored using iTunes.
Aug 09, 2009 | Apple iPhone Smartphone
How to repair/fix an overcharged L6?
I have overcharged my L6 for 8 hours now its not working
Jan 10, 2008 | Motorola Mobility L6 Cellular Phone
Apple iPhone 3G Black  Smartphone Logo
43 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
B Louis
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
