We have LG Tromm WM 2487 HWM. We are getting an error message de. The machine clicks like it is trying to lock the door but can't. Everything appears to be normal.
Posted by zspears on
Richard Lew
  • 489 Answers
You have a broken door switch and needs to be changed. The part number is 6601ER1004C. You will also need the door seal spring removal clamp tool to gain access to the back of the door switch. Without this tool, you will have a very hard time reinstalling the door seal spring.
Good luck.
Posted on Jul 12, 2011
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
LG front load washer has an error message of DE.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | LG WM-2277HW Front Load Washer
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
TROMM LG WM-2277HW
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Sep 14, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
john h
