This may be of interest.
http://www.silexamerica.com/uploads/common/GE-case-study.pdf ho
Clearly, you much be technical support within the medical corporation. It would seem reasonable to contact the manufacturer with your particular concerns. Google searches probably will retrieve insufficient technical information even if you narrow the search to "ecg corruption."
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&
SOURCE: How can I print out a stored ECG on the MAC 1200?
- Go to the storage program by pressing "Shift" + "Store/retrieve" simultaneously.
- using the down arrow, move the cursor to the space where your ECG's are listed and underline the ECG you wish to re-print.
- Once the ECG is underlined, press "Shift" + "down arrow" simultaneously. Two little cursors will state that the ECG is selected.
- Press "Enter". The cursor will come back on top of the screen, on "Print".
- Press "Enter" again. The machine will start to print.
I hope this helps !
Fel
SOURCE: How do I reset the Password for GE Mac 1200 ECG Machine?
The password should be "system." Contact Discount Cardiology for the clips, ekg paper, and whatever other accessories you may need.
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
