Question about Precor EFX 546i Elliptical Version 4
Error 12 appears on display? What do I do? - Precor EFX 546i Elliptical Version 4
Sportsmith LLC
  • Precor Master
  • 918 Answers
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
Posted on May 15, 2014
How to switch 12 hour from 24 hour in cerruti 1881 digital watch
Hold down the C for about 2 seconds (set Hold) will appear and the time offset valve will flash on the display. Press B twice to display the screen for selecting 12-hour or 24-hour timekeeping. Press D to select (12-hour) timekeeping.
Note: The PM indicator appears between noon and 11:59 PM. After all the settings are the way you want Press C to exit the setting screen.
Jun 27, 2017 | Cerruti Watches
Fixing a digital error on Richdel 508pr sprinkler system I have a flashing "Error" on my display which affects my prgramming schedule for the sprinkler. there is no reset button. Thanks.
This appears to be some kind of gardening equipment, not sure why the query is considered photographic.
However, in common with much electronic equipment, one way to attempt to reset it is to remove the battery and leave it for a period of 12 to 24 hours, then replace the battery.
Jun 21, 2016 | Cameras
12 24 hour clock
Setting the Time
Press and hold the HR or MN buttons for two seconds.
Then press and hold HR until the correct hour
appears on the display. AM or PM will appear for
morning or evening hours. Press and hold MN until the
correct minute appears on the display. The time
may be set with the ignition on or off. The clock symbol
will appear on the display in time-set mode.
Jun 18, 2013 | Chevrolet Cars & Trucks
Precor error 12
Corrective Action
May 04, 2013 | Precor EFX 546i Elliptical Version 4
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
My stove and oven froze with an error of 5ab6 bath or 6ath wont do anything
Sabbath feature.
These stoves are programmed for the sabbath.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 22, 2011 | Maytag MGR6775 Stainless Steel Kitchen...
Scanner does not work. 12 scanner error on the display
scanner does not work. 12 scanner error on the display
Jun 25, 2010 | HP LaserJet M1005 Printer
Xerox 6110 24h error
1. Press Menu until System Setup appears on the bottom line of the display and press OK.
2. Press OK when Machine Setup appears.
3. Press the Scroll buttons until Date & Time appears and press OK.
4. Enter the correct time and date using the number keypad.
Month = 01 to 12
Day = 01 to 31
Year = requires four digits
Hour = 01 to 12 (12-hour mode)
00 to 23 (24-hour mode)
Minute = 00 to 59
Note : The date format may differ from country to country
Jul 09, 2009 | Xerox Phaser 6110 All-In-One Laser...
Precor EFX 546i Elliptical Version 4 Logo
350 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
