Question about Pentair Minimax NT Heater
I need a silicone tube to replace the one that runs from the blower to the air pressure sensor. I have not been able to locate this at a hardware or pool supply. Any suggestions?
Posted by mike_lynd on
adam hudson
  • 310 Answers
470328 is the part number for that tubing. It is available at any online pool parts store, and any local pool company should have it in stock as well (if they are any good)
http://www.patriot-supply.com/products/showitem.cfm/139093
the above link is the cheapest i could find this part online
Posted on Jul 12, 2011
Baxter OV-210G burner cycling on / off @ 90 sec, repeating after new burner blower
You need to clean the flame sensor or replace the flame sensor.
Sep 30, 2017 | Heating & Cooling
F35
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. The analog pressure sensor is Key 38 in the first image below. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced. Here is the pressure sensor you can order.
Oct 27, 2012 | Kenmore Elite HE5t Washer
Gibson Furnace /c Nordyne 624631-A board, red LED flashes twice. No heat being produced.
Gas or electric? If gas make sure the line is on by checking the valve. If electric check your breaker panel box and see if it is tripped. If so reset the breaker.
Oct 06, 2012 | Heating & Cooling
Receiving code F35
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor. This error code can be caused by a problem with the air pressure tube between the bottom of the washer tub and the analog pressure sensor. If you are able to unplug the washer and check this air pressure tube, you may be able to resolve this problem. The analog pressure sensor can be accessed by pulling off the top panel of your washer. Remove the screws at the very back of the top panel and then pull it back slightly and then up and off of the washer. With the washer unplugged, check the connection of the air pressure tube to this component. Check the entire air tube down to its connection to the bottom of the washer tub. You will likely need to remove the back panel of the washer to check the entire air pressure tube. If you find a kink, tear, hose or loose connection in the air pressure tube, then this is the likely cause of your F35 error code. If the air pressure tube appears to be okay, then you will likely need to replace the analog pressure sensor. If the problem still exists after replacing this component, then the main electronic control board for the washer will need to be replaced.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
What is F35
Jan 09, 2011 | Kenmore Front Load Washer
Where is the a.i.r. pump located
The air pump for the secondary air system (emission control device) is located under the battery. If you do replace it, replace the check valve too, it is on top of the exhaust manifold and connected to the pump with a hose. The check valve fails and ruins the pump. Source(s): http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide vacuum to the climate control when the turbo is putting boost in the intake manifold. The vacuum can come from an electric pump or from an engine driven pump, something like an old engine driven fuel pump. I needed an electric pump for my 765T, and all the wrecking yards wanted to sell me the engine driven form. (A new one was $500, and it wasn't that important to me.)
An engine that takes the engine driven pump will have a hole in it while the others will not have a hole. Source(s): 35 years maintaining my own cars, including 17 years with a 1985 765T
OR
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Aug 04, 2010 | 1998 Cadillac Catera
I have a lennox ghr 26 gas hot air. have changed ignitor pressure switch control board only will run when jump out p switch. help.
If you got this far (that you jumped the pressure switch and the unit works) then you need to determine if it is the press.sw. or maybe it is not getting the pressure or vacumm needed for proper sensing. The silicone rubber tube attached to press. sw.; you must remove the end that goes to bosoter blower and (with your mouth) apply a very very gentile suction and you should hear a faint click from the switch or if it is a positive pressure system, you must give a very very gentile puff of air to the tube and you should hear the faint click. This tells you the switch is activating and the problem may be the orifice hole that the tube attachtes to (on the booster blower); it may be clogged.
Nov 28, 2009 | Heating & Cooling
MAF Sensor 2004 Dodge Stratus
If your car has a MAF (Mass Air Flow) sensor, it would be located in the air delivery tube that runs from the air filter box to the throttle plate assembly on the intake manifold. It will have a wiring connector going to it, also. The MAF does exactly what it is called: It "senses" the volume, or "mass" of the air-flow; thusly it needs to be in the intake air tube. If you do NOT have such a device in the air-tube, you have a MAP sensor, (Manifold Absolute Pressure); this is another way of measuring the same air volume, albeit older technology. You will commonly find this device on the firewall, with a vacuum line running to the intake manifold.
I hope that this sheds some light on your question.
Thanks for choosing FixYa for advice!
Feb 13, 2009 | 2004 Dodge Stratus
Amana Air Command 90 - Model GSC075A30A
water should never reach the nipple for the pressure switch tubing on the IDM. Check the entire condensate drain system for obstructions. Verify water makes it from the furnace location to the outside drain. Flush p-traps and any anti-siphon devices thoroughly.
Jan 17, 2009 | Heating & Cooling
Water will not stop filling the washer
I just fixed this problem on my GE washer that overflowed earlier into my hallway and living room. The fix required removing the tube from its connection at the outer tub and cleaning out some residue that was preventing air from moving to the sensor at the top of the machine at the control panel. No tools were needed other than a large steak knife to undo the clips to remove the front panel of the machine and a small flat head screw driver that I used to clean out the plastic pressure hose.
The good news is that even if this had not worked and the sensor/switch needed to be replaced, the part is available for replacement at the local hardware superstore and a few online outlets for around thirty dollars. Replacement of the switch looks to be relatively simple by disconnecting the existing wiring housing and replacing with a new part.
There are several detailed diagrams available online by doing a search for your product/ model number.
Be sure to check the hose before replacing the pressure sensor/switch- this will save time and money.
Jan 17, 2008 | Amana ALW880WH Top Load Washer
Pentair Minimax NT Heater Logo
Top Pentair Pool & Spa Experts
Marvin
Marvin
David Spradling
David Spradling
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
