SOURCE: Get Direct TV Remote to TOTALLY work with Magnavox TV
My TV remote has a slide-switch at the side to switch between the TV, DVD or VCR. I don't know if yours has one, if so, switch it to TV. It also has a button to switch between Analogue, Digital and External, so make sure if you have a button like this that it's switched to the right input.
SOURCE: 26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
SOURCE: My Phillips 32pw8759 TV screen is Permanently blank
There might have been a power surge that had damaged the two units. For the reset, having the tv unplugged overnight should do it. If it does not work you may want to check the power supply of the tv for leaking capacitors or burned resistors or loose solders.
Testimonial: "Thank you for your advice I will try your suggestion to reset the TV & let you know the outcome."
SOURCE: i have phillips flat tv 42pf7520d and can not
This is a commong fault on that model, you will either have to have the mainboard re-programmed, or replaced.
It has lost it's "memory" as it were.
SOURCE: Hitachi TV - no signal on DTV since switchover
Hi It sounds like you need to re-tune your DVB-Tuner on your TV, NOT the old analogue one, it'll be in settings or setup, or installation and use the "First Time Install" option, because it clears all old channels and loads all fresh new ones! hope this helps!
