Brother CS-100-T Computerized Sewing Machine Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Jul 11, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475443
Points
4013
Hello
This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
My singer soulmate 5500 keeps coming on E6 and I have a threaded correctly and the Bobben is OK so I don't know what the problem is can you help me
he error E6 on a Singer Soulmate 5500 sewing machine is typically associated with a threading error. If you have confirmed that the thread is correctly threaded and the bobbin is in good condition, here are a few other things you can try:
  1. Check the needle: Make sure the needle is the correct size and type for the fabric you are sewing, and that it is securely inserted into the machine.
  2. Check the tension: The tension of the thread may be incorrect. Adjust the tension dial until the thread is feeding through smoothly.
  3. Clean the machine: Dirt and debris can build up in the machine over time, causing issues with the threading and operation. Clean the machine thoroughly and make sure the threading path is clear.
  4. Check for thread jams: Remove any thread that may be jammed in the machine and clear the path for the thread.
I have a Brother XR9500prw, Error code E6 came on the screen. I did top thread again. No tangle so I continue to input numbers for the lettering font. The machine will do nothing. How do I fix this?
Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
2answers
How can I free up the thread take up lever whcih is seized in my brother bc2100 sewing machine?
Cut the jammed thread away, carefully. It may only need the thread path cleaned of all loose thread bits after you cut off what's gotten jammed up on the lever.
I have thread and fabric jamming issues with my Brother CE-4000. It jams and gives the E6 error message. When it's happened before, I could clean out the feed dogs and that whole area, plug it back in and...
have you checked to see if the bobbin is turned in the right direction?
have you checked to see if the top thread has come off the thread take up lever?
if these suggestions don't help then I suggest taking the machine in for a check up.
2helpful
I have error code E6 on my 7258 singer model . What is the problem?The thread is tangling up at the bobbin area.
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine top and bobbin
turn the bobbin the opposite direction
if the suggestions don't help then the machine needs to be serviced
Sewing machine motor jams when I sew thick fabric
a part of the computer is malfuctioning, & needs to be checked
try a new needle
rethread the machine using every thread guide
clean under the needle plate & in the bobbin area for loose threads & lint
4helpful
When I turn the knob to move the needle to catch the bobbin thread, it hits something underneath and won't keep going down. The same thing happens when I turn the knob in either direction. It's...
Have you removed the bobbin case to clean it? If so, it probably needs to be reseated. Remove the bobbin. Take out the case and reinsert it. If you can't get the bobbin out easily, there is probably thread clotted up somewhere under the feed dogs. I usually gently rock the handwheel back and forth as I brush the bobbin case area to begin dislodging the "clot." It also helps to remove the throat plate so you have a better view of the mechanics under the feed dogs. You'd be surprised at all the goop that can be caught but you can't see. If you do find a thread clot, use a machine brush and tweezer to gently remove each thread bit. I really hope this helps you. If it does, please come back to Fixya and rate my advice. Thanks!
Ihave anerror E6 and I can no find the problem
Hi! The E6 error means the thread is tangled. I suggest you completely unthread the machine, including the bobbin. clean out any lint or bits of thread in the bobbin area, and carefully rethread.
Hope this helps!
Robbie
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
3answers
Brother CS-6000 Sewing Machine - Jam
I have the same problem and found that the bobbin case is scratched. These are quite expensive so I hope yours is something more simple. Keeping the bobbin area clean is also a necessity.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
