Master
- Posted on Jul 11, 2011
Re: Not powering up even when power is supplied and...
- There is a diode right off the power connector on the inside of your radio. If everything else is connected properly you may need to replace it. Think the diode is D93 and it is a #1N4007 diode. It's located in the back right corner of the radio. What that diode does is allow DC Voltage to go through one way and not the other. In the case of an accidental short that diode will blow but your radio will be OK.
- Make sure to check the output from the power supply and confirm it's output with a volt meter too.
Tony
