SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
SOURCE: changing ink cartridges
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
SOURCE: hp photosmart 375
As the previous message stated, I had the same problem and it was resolved by making sure that I used the original power cable. I couldn't find it at first and tried with three others all with the same error. Finally it was resolved by using the original.
SOURCE: red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
I just had the same problem on my printer and found that resetting the printer solved the problem.
