Tip & How-To about Computers & Internet
1. Connect Your
Wireless Router
a. Power off your cable modem and
your wired PC.
b. Unplug the Ethernet cable from your
cable/DSL modem and plug it into one of the LAN ports on the back of the
wireless router. Leave other end of the cable connected to your PC.
c.
Connect another Ethernet cable between your modem's Ethernet port and
the wireless router's WAN port. (The WAN port should be separate from
the other grouped LAN ports.)
d. Power on the modem and
watch for the status lights to indicate that it's connected to your
Internet service. This may take a minute or so.
e. Plug in
the router. The status lights will blink as it runs through its
diagnostics; this may also take a minute or so.
f. Start up
your wired PC.
2. Configure your Wireless Router
a.
Refer to the router's quick-start guide, launch Internet Explorer, and
type in the address indicated in the guide.
b. Follow the
on-screen setup wizard, which will guide you through the process step by
step.
c. Enable your router's security functions. This is
very important if you don't want other people attaching to your wireless
signal. The options will be WEP and WPA. Both will ask you to enter a
key. Depending on the router's manufacturer, you may have to go into
Advanced Settings to accomplish this step.
d. Change the
default administrator's password, Almost all hackers know them.
e.
Change the SSID-the name of your wireless network. Again, hackers know
many of the default SSIDs and can use them to hack your network.
3.
Install a Wireless PCI Card in a Desktop PC
a.
Refer to the card manufacturer's quick-start guide. If necessary, run
the software installation program.
b. Power down the PC.
c.
Remove the cover.
d. Find an available PCI slot and remove
the slot cover from the back of the PC.
e. Carefully
insert the antenna through the open slot in the back of the PC,
carefully push the card in the slot, and secure it. Replace the cover.
f.
Start up the PC. It should recognize and install the new PCI card.
g.
Go to the Control Panel, select Network connections, select Wireless
Networking connection. Click on Properties button. Click on Wireless
Networking tab. Select the wireless networking name (see step 2e). Click
on Configure button. Configure your security settings to match the ones
on your wireless router.
4. Install a Wireless PC Card in a
Notebook PC
Many notebooks have built-in wireless cards.
However, If yours doesn't, you can install either a USB wireless adapter
or a wireless PC card just follow these instructions.
a.
c.
Plug your USB wireless Adapter or wireless PC Card into an available
slot on the side of your notebook.
d. Start up the PC. It
e. Go to the
Control Panel, select Network connections, select Wireless Networking
connection. Click on Properties button. Click on Wireless Networking
tab. Select the wireless networking name (see step 2e). Click on
Configure button. Configure your security settings to match the ones on
your wireless router. well, thats pretty much it. Hope this is helpful
to all you home networkers.
