Question about Saws
Early 90's stihl 029 farm boss difficult to start and won't start when hot. could this be a piston and rings problem?
Posted by scott125 on
Brad
  • 425 Answers
It very well could be. Pull the muffler and inspect the piston and cylinder for any scoring.
Posted on Jul 18, 2011
Farm boss starts runs great until hot then stops dead let it cool and it runs what do I try?
Most likely needs to be torn apart, the cooling fins on the engine need to be cleaned regularly, also you have carbon build up inside muffler, there is a screen inside muffler, if not clean, you will eventually get a scored piston and cylinder wall, then you will need much more to fix the issue, also make sure you are using the correct ngk plug
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
Sep 27, 2017 | Stihl Farm Boss Chainsaw 18"
How do I find a parts manual for a Stihl MS290 ?
I really don't want to be "that guy", but people who aren't trained STIHL mechanics or at LEAST mechanically trained, shouldn't work on higher end saws like STIHL, because people with a little bit of experience can mess something up, then blame the machine because they mess something up and start trashing the brand when it's their fault for not knowing what they're doing.
Dec 18, 2016 | Stihl Garden
I need to look at a parts diagram for a stihl 029 farm boss. I started leaking out of the vent tube tube on the gas tank when saw is on it side. There is nothing attached to the vent.
The vent hose attaches to the white nipple coming out of the tank. This hose is about 2 inches long or so and contains two little grub scews to allow a small amount of air leakage. One can be fabricated or easily acquired from a Stihl dealer. (note, the other end doesn't attach to anything)
Oct 25, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Ms330
A little more info is needed.
Compression test: a simple way is to hold the pull cord like you are going to start the saw. A strong motor with good compression tends to either stay in place or slowly fall as the piston moves. If the saw just falls down the motor is worn.
But compression increases as a motor warms up so I don't think this is your problem. If it was the saw would be very difficult to start like my dad's old Stihl 041 Farm Boss from the early 1970s.
20 minutes is a long time to run without a problem.
Consider cleaning the carburetor (or a small can of goof off) with carb cleaner - but don't get it on plastic or rubber parts only metal.
Smoke: How much smoke is there? If there is no smoke the mixture might not have enough oil causing the motor to overheat. Also, many small engines recommend regular not premium gas.
Apr 24, 2014 | Stihl Garden
Have an 029 farm boss with 16 inch bar upgraded to 20 inch all was checked and bought from a stihl dealer they even put it on. went home used it for about 15 min and the bar and chain went dry no oil going...
It sounds like you may have something stuck in the oiler port or groove of the bar. You can use the pointy end of the chain file guide to clean the bar out and give it a shot again.
Good luck
Mar 30, 2011 | Stihl Chainsaw 024 026 Oil Pump
55 rancher-put new after market piston,ring and cylinder new sparkplug,cleaned carb,tried adjusting hi lo-new gas filter,new fuel line ,cleaned air filter-will start but on acelleration bogs and dies took...
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Mar 21, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
My Stihl Farm Boss 029 leaks gas when I run it. The saw runs fine. It appears as though theres a small hose missing from the top of the gas tank. Looks like there should be hose going somewhere but its...
It could be the fuel tank vent is missing.try looking up your model number at ereplacementparts.com.It will show a diagram of whats where and the part you might need.
Mar 02, 2011 | Garden
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
