The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
Hi.
You are quite correct in saying that a new element will solve the problem.
It is usually located at the rear of the oven compartment behind a removeable cover.
Please rate my comments.
Thanks.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
