I'm no expert, but based on the general idea of operation for a turntable, it sounds like the arm is getting bound up or being hindered in some way. If you pick the arm up and swing it back and forth manually, can you feel a place in the movement that seems to have some degree of resistance? You would want to move the arm very slowly and feel for even the slightest amount of resistance. It doesn't take much force to hold the arm from advancing. An ill positioned wire in the base of the arm could be the culprit or if the unit has an automated return home mechanism, there could be a problem there as well. Maybe working the arm back and forth manually several times to its fullest allowable extension, will help to eliminate the impediment. Do this caringly and without excessive force. I hope this helps.
