Question about BOSS AUDIO SYSTEMS BV8966B Car Video Player
Boss Audio System Model #BV8966B - will not play DVD or CD's anymore & keeps saying "No Disc"
Posted by kminor1029 on
Kazim ERGUNEY
  • 577 Answers
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Some DVD players are fine at the beginning but after some time later,it begins to have some problems as you have..This is mainly due to LASER eye problems..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Jul 11, 2011
Do i need a new laser or just clean the laser?
You can try cleaning the laser lens first. The lens can be cleaned with alcohol and qtips. If cleaning the lens doesn't work, then you may have a bad laser.
Apr 24, 2012 | BOSS AUDIO SYSTEMS BV8966B Car Video...
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
No matter what DVD I load in the player, it won't play the DVD. It says "Cannot play this disk". What's the problem?
The first thing to try is to clean the laser itself by using a cleaning disc. If that fails then most likely the pickup laser is no longer any good. This is usually obvious if you place an audio CD in the unit and it plays fine : )
Jul 27, 2011 | Sony DVP-FX750 Portable DVD Player
Boss radio bv8966b is not reading the music cd keeps saying no disc
Did you try to wire it so that you could watch it while you are driving?
Apr 12, 2011 | Boss Car Audio & Video
There error reads that "this type of disc cannot
The Systems that I have is an SC-HT70/SC-HT65 which appears to be almost the same type of system. My system cannot play the following disc:
*DVD with an unsuitable region number
*DVD-audio
*PAL system discs
*DVD-ROM
*DVD-R
*DVD-RAM
*+RW
8DIVX Video Disc
*CD-ROM
*VSD
*CDV
*CD-G
*CVD
*SACD
*SVCD
*Photo CD etc.
Therefore, you will not be able to play any of these in your system.
If you are in the USA or Canada, you can play any DVDs that is marked with the number 1 or ALL.
Hope this helps
Dec 22, 2010 | Panasonic SC-HT700 System
My boss cd player would not play any cd,it keep saying check disc
Try a disc cleaner if that doesn't work the unit will need to be repaired
Jun 19, 2009 | Boss CD-3025R CD Player
BOSS AUDIO SYSTEMS BV8966B Car Video Player Logo
455 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
