Posted on Feb 06, 2018
I have a sharp CD player model C454 which is a three disk player and tape and radio player too. When I have three disks installed I would like it to play all the disks sequentially, continuously and automatically without me pushing additional buttons when one disk is done. Can this be done?
5 Related Answers
Anonymous
  • 1476 Answers
  • Posted on Jun 23, 2006
SOURCE: AUDIO
First make sure that the speaker wires haven't fallen out of the wonderful spring clip connections the factorys use. If they are hooked up properly and you have a headphone jack plug in a set of headphones and check for sound. If you have sound the problem is in the power amp. If not it could be in the preamp or power amp. At this point if sound is absent and you can solder, open the unit and check the solder joints for bad connections and resolder anythhing which looks questionable. These days the majority of problems are related to cold solder joints. If the unit still is not working you will need an O Scope to trace the signal. If this is beyond your capabilities any repair shop should be able to find the problem.
Anonymous
  • Posted on Jul 04, 2007
SOURCE: CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Anonymous
  • 36 Answers
  • Posted on Dec 31, 2007
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Anonymous
  • 31 Answers
  • Posted on Mar 10, 2008
SOURCE: 6 CD PLAYER FORD EXPLORER
usually these are not an economical repair, you either have a mechanical jam in the cd transport mechanism or you have a servo motor problem. you may be able to find a used working unit cheper then repairing you unit also when a repair is done on these changers they have a high repeat failure rate. If a local service center could just remove the jammed cd's and let it reset itself then try it again and see if it fails right away or works correctly, then you may have an idea on which way to procede
Anonymous
  • 2071 Answers
  • Posted on Jun 18, 2008
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
1helpful
Sharp cd xp 120 CD play button does not work.
The pad switch"hidden under the button" is more than likely the issue.
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Put blue ray disk in my sharp bdhp21 blue ray
Could be one of three problems.
1 - The disk is in upside down. Try turning it over.
2 - The disk is bad. Take it back to where you purchased it and get a refund / exchange.
3 - The BR player is faulty. If you have played disks in this unit before, try another disk and see if it will play. If THAT disk plays, see #2 above. If it doesn't, and you get the same error, then the unit needs technical servicing.
2answers
The CD/clock screen has stopped working...
Go to Best buy- have a new radio installed
Califone 2385AV-02
PUT AN CLEANER DISK INSIDE(DISK WHICH CLEAN OPTICAL PATH INSIDE)-YOU CAN OBTAIN IT FROM NEAR RADIO SHACK.
PUT AN GOOD CD AND TEST.
CD player not working
Insert Lens cleaning Disk, after cleaning the disk If the CD is reading change the lens.
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
