SOURCE: Can't activate answering machine
Here is the manual for almost the identical phone, in English: http://shc-download.siemens.com/repository/1321/132104/A31008-M1714-R301-2-6019_en_USA.pdf Pages 18-23 discuss the operation of the answering machine.
SOURCE: set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
SOURCE: NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
SOURCE: Lost user manual for Siemens Gigaset AL 285 twin
try pressing 0 as you listen to the messages.
SOURCE: where can I find a
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa
