Question about Razor MX500 Dirt Rocket
My razor mx500 stopped working after I went over a bump. It should have had enough of a charge to continue going for a while, but when the throttle was turned, it didn't move. After letting it sit for a day and plugging it in to recharge, it still would not work properly. If I moved the throttle ever so slightly, I could hear something going in the engine and the wheel would turn a little bit; but not enough to move me on it. Any advice would be appreciated.
Posted by shimonstroll on
3 Related Answers
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: mx500 razor
Have you checked for a frozen bearing
Posted on Feb 07, 2009
Anonymous
  • 71 Answers
SOURCE: how do you get the tire of the rear rim of the
i would suggest taking the chain off of the sprocket(cog), then loosening the nuts. then using tire-levers from a bike shop to carefully leve-off the tire. this should work....i have experience with bicycles....i race them! good luck!!!
Posted on Jun 09, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: my razor mx500 is not
Look hard for loose wires. Start with the on off switch. Make sure all are plugged up. The fuse should be accessible without taking things apart. Water is a major enemy of the solid state box the wires go into before they go to the battery.
Posted on Aug 23, 2010
It will not run it just click
Most likely, the last 2 answers are correct. When you charge the battery, does the light on the charger stay red for several hours before turning green? Check the voltage of the 3 batteries after the charger light turns green. It should be 39-40 volts or so no load. Turn the throttle and see if the voltage drops when the relay clicks. You can connect the batteries directly to the motor and it should go full speed if they are good.
Mar 02, 2015 | Razor MX500 Dirt Rocket
What is wrong when full power on throttle but only clicks
I had the same problem and it was my charger that did not work
Jul 10, 2014 | Razor MX500 Dirt Rocket
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
May 21, 2014 | Razor MX500 Dirt Rocket
How can i test electrical compontents on the mx500 dirt bike? i bought it used. it will not run the lights on the the throttle light up that the battery is full but when i twist the throttle nothing...
If the lights on a the throttle are showing a full battery then try disconnecting the brake switches at the controller one at a time. If the bike works after disconnecting a brake switch then that switch is faulty and should be replaced.
There is some excellent information on trouble shooting and testing components here http://www.razorama.com/razor-installation-guides.html
also wiring diagrams here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Oct 07, 2013 | Razor MX500 Dirt Rocket
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
My razor mx 500 motor won't turn.
I think you are talking about an electric motor on your bike . If the motor is New you may have a bad throttle switch . You can use an ohm meter to check the throttle switch . Connect the two leads of the ohm meter to the wires of the throttle switch ( dissconected) . As you turn the throttle the ohm reading should coraspond to how much you turn it .
Jan 15, 2018 | Razor MX500 Dirt Rocket
The MX500 wont start. The light says the battery is charged but when I twist the throttle all I hear is a clicking noise. Is it possibly the fuse?
Although you alternator may be charging, the battery may not be accepting the charge or holding it. Have the battery tested under load, but I think that you are going to find you will need to replace it.
May 09, 2011 | Razor MX500 Dirt Rocket
My razor mx500 is not starting the motor works and battery is charged it just doesnt start up when i turn the throttle
Aug 23, 2010 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
537 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
