Haier BC112G Wine Cooler Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Haier model BC112G that stopped working. I unplugged it overnight and it still won't work. It just makes a clicking sound once in a while. Any Ideas? Wayne
Gere knutson
Level 3:
  • Master 842 Answers
  • Posted on Jul 11, 2011
Gere knutson
Master
Level 3:
Answers
842
Questions
Helped
218219
Points
2087
Sounds like you compressor won't come on, check you warranty status before you call anyone. This repair can cost more than the unit did. The clicking noise is the overload on the compressor witch will happen if the relay fails (rare on this unit) or the compressor locked up. Either way, check warranty status on you unit before you call anyone, maybe cheaper to replace unit.... I hope this helped..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
10helpful
My Haier Commercial Cool A/C says "STOP" as an error message and won't turn on.
Bring it outside or to your tub and tip it on a 45 degree angle some water will drip out...once a puddle has come out of this thing it will work again but u will need to properly drain it eventually unless u wanna tip it and drain it every few days. But thats what ive been doing with mine...
2helpful
2answers
2answers
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
10helpful
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
2helpful
3answers
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
It seems like my compressor is not working. My Temperature is up 84 degrees F!
Your compressor should make a slight buzzing sound if working. Touch it to see if you feel vibration. Otherwise, your issue may be the compressor or components attached to compressor (e.g.: relay, overload or capacitor (if applicable).
Top Haier Furniture Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Haier Furniture Expert? Answer questions, earn points and help others
