Question about Rider Toys
Freerider Ascot scooter will not work - battery fully charged - green light is flashing
Posted by marycochrane on
  • 17,130 Answers
Possible fault in the drive selector switch/ circuit or the motor. You can check the motor, test using a DC line to confirm. If so the selector drive is faulty. check the continuity and the DC drive feed to the motor. It is possible that the circuit is not working and so the board needs a check/replacement.
Posted on Jul 11, 2011
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Jun 03, 2011 | Health & Beauty
FREERIDER ASCOT 4 Had flat batteries which now have been replaced but still no power to the motors. is there any damage that can be caused to the electronics by the batteries going flat over a period of...
No or every unlikely.
electrics may be damaged from overvoltage or overloading the motor while it is stalled (steep hill) but not from batteries going flat.
Nov 21, 2010 | Health & Beauty
Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
Toys Logo
151 people viewed this question
Top Rider Toys Experts
Marvin
Marvin
john h
WATCHING YOU
Are you a Rider Toy Expert? Answer questions, earn points and help others
