Getting limited or no internet connectivity. reset ip stack and winsock, still no dice
Posted by knowall_pand on
Abdul Mannan
  • 130 Answers
There is something wrong with the lan or tcpip settings.set a menual tcpip v4 ip from the property of connection then open the router setting page.there will be tcpip setting or lan setting "all routers have diferent interfaces for seting " or find dhcp somware.set dhcp as server mode and rang from 192.168.1.2------------------>192.168.1.64.all router have not same ip seting in some router 192.168.0.2------------------->192.168.0.64.when you set dhcp sever mode these seting will automatically done.but if you want to increase your limit then use given example.
tell me your router model so i can tell you step by step procedure
Posted on Jul 11, 2011
Error 101 (net::ERR_CONNECTION_RESET): The connection was reset. THE ABOVE ERROR IS DISPLAYED WHEN WE LONGON TO www.esic.in on display of reports. Check and revert
i also got this problem from 3 days.now it is ok .all u have to do is reset tcp/ip stacks and winsock entries open cmd type "netsh int ip reset reset.log" and press enter.this will reset tcp/ip stacks then type "netsh winsock reset catalog" and press enter.this will reset winsock entries.you have to restart windows to finish reseting ..thats it now u can log in ....if not pm me..:)
Jun 06, 2011 | Google Chrome
My recently added laptop is connected to my wireless router but can not access the internet...thanks
Try to do the following steps.
Go to run and type in cmd.
On a command box type in the word which is on bold letter.
Reset TCP/IP stack to installation defaults, type: netsh int ip reset reset.log
Reset WINSOCK entries to installation defaults, type: netsh winsock reset catalog
Reboot the machine.
Mar 21, 2011 | Computers & Internet
My IE 8 will not open any web sites
Is your Network Connections working properly?
If your networking adapters are functioning OK, try this,
Open IE
Tools tab > Internet Options > restore Adanced Settings and Reset Internet Explorer settings.
Restart IE.
Other options are:
1) Uninstall the Network adapter
Open Device Manager > Expand Network Adapter > Right Click on your internet network adapter and Uninstall
Reboot
If it doesn't work, try it again and then reinstall the driver. You may have to get the new driver from the device website.
2) Winsock and Tcp/Ip Fix
Start > Run > Type CMD > Type the following:
type: netsh int ip reset reset.log and Press Enter
type: netsh winsock reset catalog and Press Enter
3) Run sfc /scannow (This will restore your system files back to original state)
Insert your XP disc
sfc /scannow
Hope it helps.
Jul 15, 2010 | Microsoft Internet Explorer 8
Hi, i am using dell insprion 1525 laptop. i am faceing problem in netwoek drivers . i am not able to install network drivers and at lan card palce i am getting red light please help me .. praveen kumar
Boot the computer in Safe Mode with Networking and see if it connects that way. If not, try this fix.
TCP/IP stack repair options for use with Windows XP with SP2/SP3.
Start, Run, CMD to open a command prompt:
In the command prompt window that opens, type type the following commands:
Note: Type only the text in bold for the following commands.
Reboot the machine.
Download Network driver :- R161378.EXE on support.dell.com
Jan 16, 2010 | Dell Computers & Internet
Wireless connection
Start->Settings->Control Panel. Double click in Internet Options.
On the Connections tab, click on Never Dial a Connection. While you're there, click on LAN settings. Automatically detect settings should be checked, but normally nothing else should be checked.
If this doesn't help, you may need to rebuild the stack:
Start, Run, CMD to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine
Apr 16, 2009 | Computers & Internet
Router works at computer store, but not at my home
Try to reset the TCP/IP stack and the Winsock by the following way:
In the Start menu -> Run enter cmd.exe (press OK or hit Enter)
In the black command prompt enter the following commands:
Hope this helps.
//Feri
Mar 17, 2009 | Computers & Internet
PROBLEM WITH NETWORK DRIVER
I don't know how happy you will be to try the following:
Go to Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reboot the machine.
Aug 28, 2008 | Microsoft Windows Vista Ultimate Edition
Linksys can't find ip address
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reboot the machine.
Aug 13, 2008 | Linksys Wireless-G WRT54G Router
How to connect wire less connection with my laptop,
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
Edimax 4 ports broadband router wont connect
Try dong a TCP/IP stack repair Start -> Run -> Type CMD to open a command prompt. To reset the Winsock type this into the commnad prompt: netsh winsock reset catalog Next To reset TCP/IP type this into the command prompt: netsh int ip reset reset.log Then reboot your pc and see if that helps. If not let me know.
Sep 23, 2007 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
Ekse
Marvin
Marvin
