Cars & Trucks Logo
Posted on Jul 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1993 Subaru impreza hatchback 4d with the 1.8 liter engine. I opened the back hatch and put my bike in it this morning and this afternoon I attempted to take it out but the handle failed to open the hatch. I used the power locks which sounds like it worked but again the door failed to open. I used the key manually and the same result. I do not understand how a door that has worked thousands of times can all the sudden stop operating. Any advice on how to open the back hatch again would be appreciated. I use the back hatch every day so this answer is of great importance.
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jul 11, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
12381
Points
111
There could be a button or something similar on the inside of the door to prevent it from opening by kids or by accident which you could trigger when you put in your bike. Hope this helps.
1helpful
2answers
1993 Subaru Impreza 1.8l. I was wondering if anyone may know how and which spark plug wires go? Two are short and the other 2 are long. Thanks
the last video is for wrong engine of 5 engine
his (OP) is 1.8L boxers and has a Distributor. 4 cyl
2nd video is wrong, no distributor. has coil pack
2nd video is 2005 and worthless.
1st video, is wrong too, is OBD2 car, 1993 is not.
1st video does not distributor
most youtubers never ever tell year nor which of 5 engines are there,and watchers pull hair out endlessly. (wasted time and efforts)
this car goes back to 1992 , vast changes,by year
1996 (first obd2 )1.8L has 4 lug DIS coil pack
that too has special connections, ask for help
boxer is h4 engine, H= horizontal.
all answers USA
if not here engine spark can be totally different world wide.
ours had a distributor 1.8L USA. EJ18 engine.
1992 to 2023 car,but wiki says
1998 (the same year the 1.8-liter engine was dropped
so is only a 6 year run.(1.8l)
31 year run, all engines. other 5 (set)
Changed light bulb on 1993 subaru impreza now car won't start, everything lit up on the dashboard
1993 Subaru Impreza Won't Start! - NASIOC
forums.nasioc.com > ... > NASIOC Technical > Service & Maintenance
Sep 12, 2004 - 3 posts - ‎3 authors The car has been running fine, but recently in the morning especially, it won't turn over. I crank it and its trying to start, but there is no spark. Car won't start, cranks but no start. - NASIOC - North ...
Aug 26, 2013
car wont start, getting fuel and spark - NASIOC - North ...
May 22, 2012
HELP: Car won't start after timing belt change - NASIOC ...
Sep 23, 2008
Weird starting problem--1993 Impreza - NASIOC ...
Mar 4, 2003
More results from forums.nasioc.com
my 1993 impreza wrx wont start please help - ClubWRX.net
www.clubwrx.net/.../134323378-my-1993-impreza-wrx-wont-start-pleas...
Dec 5, 2009 - 7 posts - ‎2 authors can anyone help me, my 1993 impreza wrx wont start, 2 days ago i went to ...ClubWRX Forum - Subaru Impreza WRX and STi Community and ...
1helpful
What year manual transmission fits to a 2004 Subaru Impreza WRX?
Pretty much any "EJ" transmission will fit any "EJ" engine, the only problems are whether the clutch is a pull or push type release bearing? That will also make a difference how the clutch slave cylinder mounts up. If it isn't a turbo model trans, it will not take the HP that the engine puts out for very long. The Impreza STI manual trans will bolt up, but there will be some exhaust fitment issues where the down pipe bracket connects to the trans.
I have 1993 Subaru impreza and I don't have transmission light and have a check engine :(
some time is the oxygen sensor .make sure put on computer first
1helpful
Wiring diagram subaru impreza ej15 - gc1 -
For the 2.2 1997 Subaru Impreza:
Firing Order:
1-3-2-4
Cylinders:
(back of engine)
_____ ....._____
|...3...|.....|...4...|
|...1...|.....|...2...|
(front of engine)
Ignition Connections:
......(back)...
o|<-3.....4->|o
o|<-1.....2->|o
.....(front)
Let me know if this helped, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
1998 impreza engine in a 1993 impreza *** import
Hi the engine managment system in your 93 impreza will not run a 1998 engine. If your using the complete motor with inlet manifold and turbo you will need the get the correct engine harnes and ECM.
2answers
I can't find the coolant temperature regulator on my Subaru
Hello, your coolant temp sensor is mounted on the cylinder head coolant crossover pipe. If your standing at the front of your car with the hood open, if your looking at the engine the sensor is to the left of the throttle body under the intake manifold. I think it takes the open end of a 19mm wrench to unscrew it. There are 2 sensors back there and it's the larger of the 2.
1helpful
1993 subaru impreza L heater is not working
if the engine temp seems normal on the dash gauge then it may be a clogged heater core.have the sysyem flushed-it worked for me recentlythe other options may be a heater door not closing..some are vacuum activated a flush is a good place to start..good luck
Top Subaru Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Subaru Expert? Answer questions, earn points and help others
