When turn on this lcd only picture flasher a few second and then picture go to black the light green into front panel is on
Posted by hunava2006 on
Frank Fulton
    President:
  • 1,114 Answers
More than likely, you need to replace the lamp. Check in your manual for power lamp flashing troubleshooting. It will flash 3, 4, or 5 times then pause and repeat. You can find lamps online, check EBAY. Hope this helps
Posted on Jul 11, 2011
40" Toshiba TV - Flashes on for a half second, then no picture
Sounds like main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Toshiba 40E210U 40 in. LCD TV
Toshiba 40" turns on for a few seconds, then turns off. No picture!
Consider having it repaired as it should be in warranty.
Apr 30, 2012 | Toshiba 40E210U 40 in. LCD TV
Spetroniq 42"lcd screens black no picture no
Sounds like maybe power supply, but I would check with flashlight 2 in from screen when the green light comes on to see if you have a picture, if so then you have a bad inverter board, if not then power supply problems. You can look for bad or bulged caps in PS
Jan 06, 2011 | Spectroniq PLTV-42HW68 42 in. LCD TV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv is on, after a few minutes it goes black and there is no sound. The indicator lamp is still green and stays solid the entire time. Without turning the TV off, in about a minute, you hear a small buzzing...
Someone else gave me the tip as I had the EXACT problem, but no buzzing. Unscrew the panel on the front bottom of the tv. Once that is off, there is another screw that opens a little panel. Unscrew the single screw with an allen wrench and pop out the bulb and casing. Mine was full of dust etc. Used an LCD cloth, but compressed air would do the same thing, put it back together and it works great!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Picture goes blank after a few seconds of turning on power
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
May 24, 2009 | Samsung LN-T4665F 46 in. LCD Television
LG Flat Screen Problem
since when have you experienced the problem? does the tv still turn on or not...?
Aug 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Open Questions:
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
