Question about Under Armour Impulse Sunglasses
The rubber nose piece is tearing - Under Armour Impulse Sunglasses
Posted by jkp2116 on
Have a tear in the rubber on the mask under the nose piece. Can it be repaired?
Repair is unlikely to be satisfactory. You probably will have to replace the mask
Aug 27, 2013 | Scubapro Scuba Diving & Snorkeling
Tip
Save even more money! I did this repair for under $20. Instead of replacing the...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on May 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine leaks water
The most common place for a front load washer to leak is in the bellow. This is the rubber piece right inside the door. Pull the rubber piece back and check for tears or holes. If there are not any holes then there is probably a hole in the hose that runs from the tub to the pump. Sometimes stupid things like bra underwire and bobbi pins get in here and tear them
Aug 25, 2012 | Maytag MHWZ400T Front Load Washer
I have a pair of Tag sunglasses. I believe the model number is 6008 102 but the full numbers that are on one temple are 115/1 30 TH 6008 102 59 1703. There is a rubber nose piece that is mounted on a...
go to the official Tag Heuer website, www.tagheuer.com, look for the retailers in your country chose the one nearest to you and contact him The name of the model is TH 6008 102
May 17, 2011 | Tag Heuer Clothing Accessories
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
I have a paper jam. Some of the paper is still stuck in the rollers. Machine said to open back door. I did and can see the pieces of paper but when I try to pull them out with a pair of needle nose...
HI, Try to roll gently and slowly the paper roller and pull the piece of paper in the same time. Grab the piece of paper close to the roller to prevent tearing. Good luck!
Mar 03, 2011 | Dell 5210n Laser Printer
The littel rubber boot at the end of the spark plug wire is stuck on top of the spark plug so how would i go about getting it off so i can take the spark plug out?
Spray some wd-40 or other lubricant in the hole where the wire was in. Use long nose pliers and dry to turn the boot. once it turns it will come out.
Feb 15, 2011 | Toyota Camry Cars & Trucks
Replace rubber nose pieces
use small pin or maybe hairpin to unclog the said rubber.
Feb 01, 2011 | Tag Heuer TH 5104 Sunglasses
I have a pair similar to the EV0253 and the rubber on the nose piece bridge has disintergrated due to interaction with sunscreen. Can I replace the nose bridge piece?
hi
you can certainly replace your nose piece bridge by taking your cool sunglasses to the show room where you brought with the bill they have given you but you should have warrente or you need to pay for it but it wont cost much . or you can vist the site below ,for reparing your sunglass
http://eyewearus.com/pd.asp?prod_id=10918&txt_brand_id=174&cbocat=1
Nov 18, 2010 | Nike EV 0253 Sunglasses
Under Armour Impulse Sunglasses Logo
264 people viewed this question
Top Under Armour Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you an Under Armour Clothing Accessory Expert? Answer questions, earn points and help others
