Question about Toshiba 55H70 55" Rear Projection Television
Tv will not turn on the light on the front just flashes. It worked fine in the morning came home from work and can't get it to work. I unplugged it figuring it would reset.
Posted by c_persenaire on
Frank Fulton
    President:
  • Toshiba Master
  • 1,114 Answers
If you still have the manual, look in troubleshooting for "Blinking LED" this is a diagnostic tool used to help determine the problem. It could be as simple as a lamp or it could be the power supply.
This is the link to your manual if you don't have it.
http://www.fixya.com/support/p203662-toshiba_55h70_55_in_rear_projection/manual-5605#
Hope this helps
Posted on Jul 11, 2011
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Tv will not come on
  • check to see if tv has sound when you turn on, then check menu for color, check if tv might be on timer. this might help!!!
Mar 19, 2009 | Sanyo DS27510 27" TV
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
I can't turn on the TV.
I had the same problem. Unplugged it, reset it, everything. I went to work the next morning and left the light blinking, came home from work and it was off. I turned it on and so far, so good. Just give it some time to reset internally
Aug 26, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
