McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
Posted on Jul 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine runs fine but probably overloaded the generator. Is it just brushes or coil too.
JOHN LAPIER
Level 3:
  • Master 2,602 Answers
  • Posted on Jul 11, 2011
JOHN LAPIER
Master
Level 3:
Answers
2602
Questions
Helped
898694
Points
8635
Site unseen i would say its neighter the brushes or the coil . And more the likely the problem is with a transformer converting the DC off the generater to AC for your output . If the engine runs ok and the armature in the generater spins ok and you don;t have a million hours on it should work at least somewhat . Try testing the output on the AC side see what you get for AMPS you will need a muilty meter set to AC amps
3answers
My ranger 8 runs fine, but no output, was told it has a breaker on the inside, but can't find it, where is it at
this
engine dead.
or good and welder side dead
buy the service manual from Lincoln??
2answers
Does over load causes over heating of the engine on a generator
Yes, it can.but how is the airflow over the engine? If the air is being blocked, that will overheat it too.
Why does muffler get red and stays red while running?
Red muffler? that can be caused by restricted cooling airflow over the engine, excessive carbon build up in the cylinder, and also way too lena a fuel mixture. Also be cautious of engine overloading
1helpful
2answers
I have a miller trailblazer 301g. It worked fine yesterday and now only the 120/240 volt outlets will work. No weld output and also the idle will not kick down. when I opened the unit the only visable...
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Generac 5250 with a 8 hp Honda engine. Runs fine, no output
Take a resistance reading across the brushes with and Ohm meter. (not running) You should read a low resistance. If you have no resistance across the brushes then then either the brushes are not mating with the armature or the the armature is open.
IF you have resistance then the AVR (Automatic Voltage Regulator) in the endcap has failed. With the engine running and the Brush block disconnected you should have 4 - 12 VDC on the two wires going to the brush block. No voltage = bad AVR.
Thanks for choosing FixYa.
Kelly
I was running two sawzalls on my pmo43350 coleman generator .Now it stopped producing electricity. the engine runs great but no juice to outlets. ithink i overloaded it.
You may have overloaded it, and it may have been damaged.
Check your circuit breakers first. If there was an overload, they should have tripped if overload was long enough in duration and high enough in capacity.
If the breakers are good, then check your diodes and capacitor regulator in the end of the alternator. While you are here, check your brushes as well.
Do you have a manual for your generator?
1helpful
4answers
My HONDA EM650 GENERATOR is not producing enogh power to even run a Hair dryer , does anyone have an idea what the problem might be?
The problem might be with your eyesight. This small generator produces a maximum output of 650 watts. Any hairdryer uses way more than this, as you could see it on the label.
Generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
2helpful
2answers
My generator starts and runs great, It is not
I have a Coleman Vantage 3500 motor runs no generator output
This sound like a loss of residual magnetism in the generator. The field will need to be "flashed".This is also known as re-exciting the field of the generator.
The Coleman manual gives these steps:
1Use a 6 Volt lantern batters (dry cell) or a 12 Volt automotive battery.
2.Disconnect all loads from generator.
3. Remove the brush cover (that's the rectangular plastic cover on the end of the generator.)
4. Plug a lamp or light into the generator before starting the engine. The light will illuminlate when ?Voltage has returned.
5. Start the engine with no load connected to the generator.
6. Attach the "-" lead of the battery to the negative brush. Very briefly touch the "+" lead of the battery to the positive brush. Remove as soon as Voltage builds up.
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
