Nokia 7510 Cell Phone Logo
John Rys Posted on Jul 10, 2011
My front display is cracked-I have a donor phone. How do I take them apart to fix the the good phone? Thanks, John
How to replace broken screen on cell phone?
they have to be identical phones to start with
best if you take both to a phone repair shop as they have the expertize to do the job with out causing more problems
Apr 25, 2016 • Cell Phones
1helpful
Can I jump start a john deere 445
Yes, you can jump start it with any 12 volt battery on any vehicle. Just do not have the donor vehicle running. Connect the positive cable from the donor battery to the positive post on the battery on the mower. Then connect the negative cable from the donor battery to the engine block or other ground source on the mower. Do not connect it to the negative post on the battery. Make sure you have a good connection on bare metal for the negative cable. Disconnect the negative cable the instant the mower starts.
Change front flipup on razr phone
Remove 4 small black rubber pads.
Remove 4 small silver silver.
2answers
Front glass on iphone 3g cracked
This is intence, good luck http://www.youtube.com/watch?v=X1z0pw2VK7M
4helpful
2answers
KT-SR3000
Had this problem with mine. turned out to be bad solder joints. Take the unit apart and solder these joints and it should fix the display problem.e0ae4d7.jpg
1helpful
Dimage x50 konica minolta digital camera
If the LCD was physically cracked or broken, then yes you should be able to swap it for an undamaged one.
The cheapest option for you is to advertise or look on Ebay for an identical model - also with faults, but with an undamaged display. (maybe dropped - sold as not working)
See HERE - this is just like yours - but also has the cracked LCD. You need to search for one with a good display.
Take this "donor" apart first to see how it's assembled, then just swap the parts.
This method of repair is common for consumer electronics.
Thanks for using Fixya!. If this has provided a solution, plrease rate as such. Thanks.
Razr V3i front screen.
Dear oldgit72
Use the following guide to take apart the phone's LCD
http://www.formymobile.co.uk/Dismantle/v3lcd.pdf
If you need extremely analytical instructions these can be found here.
http://www.formymobile.co.uk/Dismantle/v3disassembly.pdf
I hope you can fix your phone.
Regards
EngineerGR
Please dont forget to rate this solution if you found it to be usefull.
Cracked case
DON'T! you can do more harm then good taking the phone apart.. specially the front lid.
The hinge has a ribbon cable that runs through the left side hinge .. If that's torn there's no fixing anything anymore. Your better off just seeing if Verizon wireless can replace it for a fee.
5answers
Dim display on LG enV 9900
did you try going into the settings
from the front
(Menu -> Settings -> Display Settings -> Backlight -> Display -> Front Backlight -> put Always On)
Same from the inside but main instead of front.
2answers
Blinking Blue Power Led on front, Monitor is non-responsive
Hallo.Sorry for me english first.I have question.You plugg in a monitor with a notebok,or dektop pc? If you conect monitor with a notebook, i thing, you must change a display settings.This is very easy.On the ntb keyboar press and hold Fn-key and at same time press f4 key,and you cann chage the output canal for video signal,Lcd in notebook,external LCd or Both. I hope, it will help for you. Bye Perdo
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
