My packard bell imedia x2414 does not boot up and then switches itself straight off. also the blue/orange power light is red constantly when trying to switch on..any help plz
i'd say your not passing the post test....if you hear a beep when you start your pc it should boot to windows screen if you dont hear beep you could have a loose cpu fan open up pc and make sure the fan is secure if not try tightening it can be tricky either that or it could be your power supply i wouldnt attempt fixing that if not sure what your doing..or try turning off your pc plug it out disconnect all periphals and press in the on button and hold for 2 minutes then try and boot
If possible, clean the inside of the laptop free from dust, then reseat and re-paste the CPU with heat sink paste.Tighten everything properly. Please do all of this when the unit is both OFF battery and OFF A/C so do this when the unit is not on ANY power.
Sounds like an overheating problem. Clean the dust out of it, make sure it can get air on all sides, make sure the fans are turning. If that doesn't work, unplug the computer, hit the power button 20 times, wait 1/2 hour and boot it up.
Assuming the monitor is fine you can try the following:
Open the machine and reseat the video card; if video card is onboard try
Unplug the machine and remove the CMOS battery for a few minutes; Its possible Windows didn't shut down properly and CMOS is preventing a normal startup; after replacing the battery, boot up (will probably start up in safe mode
If neither of these fixes the problem, you may have an issue with the monitor itself. Best of luck.
Greg
