Samsung DVD-V4600 DVD Player/VCR Logo
Question about Samsung DVD-V4600 DVD Player/VCR
Most times (90% or more) I input a DVD, the TV screen says Loading, and seems to be processing the DVD loading procedure, but then doesn't play the DVD -- it stays stuck on the Loading sequence. Any assistance is appreciated.
Posted by ebarplus2 on
Kazim ERGUNEY
  • 577 Answers
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Jul 10, 2011
My dvd player on the tv doesn't work how can i fix this problem so that i can watch movies
The disc loading mechanism to your combo is faulty. To repair it, you have to disassemble the whole unit. It is a skilled work. Seek tech support.
The input dvd screen says no signal and the DVD player doesn't seem to have any power.
If it is in warranty return it---parts for the DVD unit are not available--they would have to replace the entire DVD unit inside the set.
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Soniq qsl322tv5 flat screen tv says
Hi, Unplug the TV for 1 hour and try again. The TV will reset to default. Good luck
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
1helpful
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
I can't get the dvd player on the tv. I don't know
I've reviewed your post, evey2011, and would be glad to assist you with this! The DVD should plug directly into the TV. When you plug the cable into the TV, there should be some type of designation for the ports, such as AV, Video, or Component. What you should do is look for the designation of the ports. If you can't make it out, put a DVD disc in the player and have it playing, then use the TV remote to cycle through the inputs on the TV to find the picture input.
Hope that helps and let me know if you have any further questions!
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
5helpful
3answers
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
 Grubhead
Grubhead
