If the printer is plugged into an AVR or a UPS try
plugging it directly to a known good power outlet to make sure that it's
not the UPS or AVR that's causing the trouble.
Another thing you
can try is to make sure that the power cable is ok. Eventhough it's
intact wires from inside the power cable might have melted so try
swapping power cables or if you have a power tester check for the
continuity of electricity on the power cable.
If both looks good
and the printer still does not want to turn on, check if the power light
has any sign of life, does it give a blinking amber light or no light
from the printer comes out at all?
If there is a blinking light
or a steady amber light try to remove all the printer components (inks,
cartridges, etc. and put them back in then try turning the printer on)
If
it still does not work please provide the model number of the printer
as a service might be needed to make sure that the capacitors, IC's and
the PC-board of the printer is ok.
P.S don't forget to check the fuses to make sure that they are in good condition.
Hope this helps!
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using FIxya
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
