Question about Nintendo Video Game Consoles & Games
Are you able to buy a replacement motion sensor( the 1 that goes on the top of your tv.0 The dog chewed the wire that goes into the console
Posted by amandaputter on
Anonymous
  • 1,139 Answers
Hi there, if this is for the Wii then yes, you can buy a new sensor bar very cheaply, something like this is needed -
http://cgi.ebay.co.uk/WIRED-INFRARED-RAY-SENSOR-BAR-NINTENDO-WII-STAND-/370479331614?pt=UK_VideoGames_VideoGameAccessories_VideoGameAccessories_JN&hash=item564249f91e
Just search for Wii sensor bar in ebay and you should find what you are looking for
Posted on Jul 10, 2011
I need to buy a replacement remote. Our dog chewed up our remote and I can't find a replacement for it.
How come dogs chew our things instead of their toys? As the first answer suggests search the manufacturer's website. If its an old remote then try Ebay. Sometimes a local pawn shop has a box of remotes that you can look through. In the meantime you can always buy a generic universal remote that you can program to work with your TV.
1helpful
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 • Vacuums
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
My dog chewed the cord at the plug and the plug is ruined
There one of two ways you can fix it, go to a hardware store or Radio Shack to buy a replacement plug "strip wire and screw into plug" or have a tv technician hard wire a proper cord with a plug end in the set "best solution"
Dog chewed the gray water mist cord, can i replace the cord?
mcdevito75 here, Best bet, Look for any appliance repair center in your area for replacement electrical line. If your handy yourself or know a handy person, simply match up the electrical cord with another at your local hardware store, Splice the new cord into the old one.
2answers
My dog chewed through a group of multi-colored wires on my AC outside. Is there any way that i can fix this?
HI there well i think what you dog chewed on was the thermostat wires. if you tell me the colors maybe i can help you out.
[email protected]
This is my e-mail
Dog chewed through wires to the sub
It should work. Make sure that the joints are soldered and properly insulated
Dog chewed sensor wire so garage door won't, i
Basically any bell wire will work, available at any home centers everywhere. if the existing wire is long enough, just wire nut it together (white to white, color to color)
Direct tv cable
ok if its only the rf cable and the ac cord yes you can do it your self.you have one cable out from the sat reciver going to the dish. Find an area that the pooch didnot chew through cut off the bad part of the wire. find the wire that goes to the tv set. if its the coax disconnect from the reciver on both sides and go to the store and buy a new cable (unless you have coax wire and know how to put on f fittings) also while your there buy a small extenstion for the other cable you cut. also your gonna need a a female barrel connector as we;ll as an rg6 type rf fitting for the end you cut. have the guy at the store explain to ya how to put on a f fitting. If the ac cord was chewed buy a simple cheap extenstion cord too. Go home and first put back on the cable you took off the output of the sat reciver and the other end to your tv set. then put on the f fitting the guy explained to ya how to put on and then install the barrel connector then the short extention wire to the other side of the barrel connector then the other end of the rxtenstion cable to the sat output. Now if the power cord is chewed im surprised the pooch is not fryed!!!lol Simply cut off the bad part take the extention cord and cut of the end you dont need take off about 1 and a 1/2 inches of the insulation on bothe parts(reciver and cord) twist together and tape separatly or use wire nuts on them . then you are good to go. BUt one more little thing are you using video cables between the tv and the sat. reciver?? well why didnt you say so LOL simplyu pull out of both ends and go to rat shack or something like them and buy an inexpensive pair of cables and remeber yellow is always video red is alway right audio and white is left audio Hope this clears things up for ya.!!!!
Video Game Consoles & Games Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
