SOURCE: help... How !!!!
well I don`t know much about mp3 players...but i do know that it is sort of tough to find answers. To load a type of file, Example: music, you click music on the media manager software prgra, and then you click on the button that says add folder. go into your documents to find the music that you want to put on the device. left click on the mouse to drag up the songs you want and click OPEN. make sure your player is in and then hit download. your multi media player will have more media.
Later,
Lollipop
SOURCE: My GC820 is not working
The firmware does not need to be updated. After a mode is selected by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
