Question about Fujitsu Siemens MCM 173V (White) 17" CRT Monitor
Monitor works ok then suddenly loose picture(black screen) turn monitor off then turn it back on works for approx 5 secs then goes back to black screen
Posted by retroman123 on
Gilbert Jalimao
    Sergeant:
  • 243 Answers
There are many reason why a monitor suddenly turned off then back to work again , over use may over heat that cause the soled parts on the printed board of your CRT go loosen , try to re sold it, sometimes your PC might stop viewing so the monitor automatically shot off stby mode , loose connection due to basted parts , capacitors,power regulators,resistors , even the cables also might be.
Posted on Jul 10, 2011
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
Monitor goes black after about 7 to 10 seconds. I can turn power off and then back on and it will be ok for about 10 seconds before it goes black again.
Check whether the cable from the system to the screen is connected properly and there is not loose contact. Also take the system into BIOS and check whether the same issue is happening in the BIOS screen.Try a factory reset on the screen by pressing the OSD button on the screen.
Switchoff the screen and disconnect all teh cables including the powe cable and press and hold the power button for around 40 sec and now reconnect the cables and try to power up the screen
Jan 04, 2011 | Proview PL926WBi 19" LCD Monitor
Monitor flickers and goes blank after 5 seconds and keep repeating this very often.
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 26, 2010 | Acer AL2016W 20" LCD Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Samsung 204B has a *very* long response time, b-w approx 10sec
I looked at the picture, well you have me stumped. Caps look OK. CapS on Logic board look OK.
Apr 12, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Everything was fine and the all of a sudden screen went black, then desktop picture comes up for about 1/2 sec, barely time to read it, then it goes to black for about 4-6 seconds before repeating cycle....
the CRT is shorting out which is why its coming on and turning off. If you bring it to an electronics shop it will at least cost $100 assuming they can do something with the CRT. If not then it will be more and you would be better off getting an LCD monitor and they are usually around $125-$140 for a 19" on sale.
Jul 07, 2009 | HP Compaq FS 7550 17" CRT Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Fujitsu Siemens MCM 173V (White) 17" CRT Monitor Logo
255 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Erni Mallari
Erni Mallari
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
