Question about JBL - MR4W Am/Fm with CD Player White
JBL MR15W won't play CD - error code 006
Cd player error
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
Jan 02, 2014 | 2007 Toyota Camry
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
Error 3 on my 6 disc CD changer The manual says to eject and re-insert disc, but the player won't eject or play or change discs. What is the fix?
try disconnecting power to the radio for an hour or so. usually it is best to disconnect the battery overnight to reset the microprocessors.
Feb 28, 2011 | JBL MCDC100 6-Disc CD Changer
1996 ford explorer with JBL sound system with 6 CD changer, keeps saying BAD CD when asked to play
Welcome to Fixya
Try to use cd cleaner first to clean the lens. Its giving you a BAD CD error because the lens cannot read the disc. Do the cleaning method 2 times.
Please reply to this email for any update.
Thank yuo for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 03, 2011 | JBL MCDC100 6-Disc CD Changer
Jbl six cd car stereo with, code error 3
Error code 3 generally means CD is stuck and unable to eject
Jun 22, 2010 | Car Audio & Video
CAR CD CHANGER - ERROR 3
replace head unit the cost to fix the problem you could but two deck ,use a wiring harness and get the aftermarket mountain kit
Jun 09, 2009 | JBL GTO75.4 Car Audio Amplifier
Help
I'm having the same problem. I get an error message for the first cd, but will play ever other cd.
May 17, 2008 | 2003 Toyota 4Runner
Error 4 - JBL in Toyota Land Cruiser
need to know what year and model of land cruser
May 07, 2008 | JBL MCDC100 6-Disc CD Changer
JBL - MR4W Am/Fm with CD Player White Logo
66 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
