Question about Refrigerators
We have a Jenn-Air French door refrigerator. It's about 4 years old. It is maintaining its temperature fine. But all of a sudden, about 3 hours ago, there is a constant sound similar to a squeaky door opening and closing. It's about a 2-3 second sound and then a 2 second break with no sound, and then it repeats itself....constantly. Thank you
Posted by proakes on
Kelly
  • 3,740 Answers
This is most likely a door open alarm caused by a problem with the door / light switch. Locate the light switch plunger and depress it. The light should go off. If the light does not go off the door switch has failed. The door switch is removed by sliding a thin bladed knife along the side if the switch and releasing the locking tab. The freezer door only has one locking tab on one side of the switch. The fresh food compartment door switch has 2 locking tabs on opposing sides of the switch. You unlock the tab(s) and remove the switch. The fresh food compartment door switch has 2 wires on it that close when the door is closed. The freezer door switch has 3 terminals on it. One terminal is C common. One is NO Normally open and once is NC normally closed. The NC terminal will have continuity to C with the punger extended. The NO contact will have continuity to C only when the plunger is depressed.
I think you have a bad door switch. If the freezer door switch fails the unit will stop making ice.
Thanks for choosing FixYa,
Kelly
Posted on Jul 10, 2011
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Jenn air french door water dispenser broken
You have two sides to your 67006531 Dual Water Inlet Valve, so it is very possible the side that controls the water flow for the dispenser is defective. Replace the 67006531 Dual Water Control Valve and I believe your fridge water will work fine.
I will be here should you have more questions, Thanks Sea Breeze
May 20, 2012 | Jenn-Air JFC2070KRS Bottom Freezer French...
Problem with the water dispenser in the Jenn Air Refrigerator
Did you find a solutioin to this problem? I have the same exact one?? Thanks
May 29, 2010 | Jenn-Air JFC2089HE French Door...
I have a major dent in the right door of my french door Jenn air fridge what is the cost of a new door.Model JFC2089H Stainless.
Depending on the part supplier the door will run about $400.00 to 700.00, I know that is really high!
One option you may have is to call around to service companies that work on Jenn Air, they may be able to look out for a door that they are replacing for someone that only has a small dent or scratch, and rather than scrap the old one, recycle it with you.
Not sure if that is an option but worth a shot
Apr 18, 2010 | Jenn-Air JFC2089HE French Door...
Same as below...
HELLO,
Is this fridge more than a year, if it is, then I would kindly suggest, :) to have a new coolant installed, and then run the fridge some time, it should kick back to normal...:)
Sep 09, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Gone Crazy
you have to adjust door may be is the filter or water valve some time the indicator filter dont come on on till filter singal it
Mar 18, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
