Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried turning off both printer and computer, waiting and then restarting but still the printer will not print.
Posted by bjcrow on
JDTec
  • Canon Master
  • 4,338 Answers
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 10, 2011
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
Canon pixma mp272 printer. replaced black cartridge for the first time and now it wont print. getting error p08 on the printer and error 5200 on my laptop screen
Hello Hellen,
the error P08 is error for abnormal temperature in print head. Aa possible cause the ink cartridge is faulty and needs to be replaced.The same error description is for 5200 on your PC.
I recommend that you try to replace ink cartrigde under warranty in store where you bought it. If after that you still have error, take the printer to the service center because they logic board ( pcb ) is faulty.
Hope that helps!
Aug 25, 2011 | Canon Pixma MP270 All-in-One InkJet...
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Error Number : 5200 A printer error has occurred. Turn the printer off and then on again. If this doesn't clear the error, see the user's guide for more detail. I have tried turning it off and...
Hello and Welcome to FixYa!
Error number 5200 is a
service error. To solve this error follow the given steps:-
  1. First of all unplug the printer
  2. Open the top and bring the ink cartridge holder to the middle
  3. Raise the gray bar and remove the print head assembly with the cartridges in it
  4. Lower the gray bar with the head missing and close the top with the head out
  5. Restore the power,wait till the printer starts
  6. It will tell you to put in the cartridges, Put in the cartridge
  7. Restore the print head, close the top and the printer will resume working
Error will be removed.
If you have already tried all of the above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
Any more confusion, queries or for further assistance, I am here to help.
I hope this solution helps you
Thank you for using FixYa!
Jun 07, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    Cannon pxima MP 357 no printing & search for e 5200 error to the manual user guide
    error 5200 means the printer is unable to detect ink cartridge.
    I do suggest you remove the ink cartridges from your printer. Examine the surface contact to where the terminals inside the printer touches. Clean this surface with clothe moistened with alcohol.
    After that reinstall the printer and see if the printers successfully detect the cartridges..
    Press the stop / reset or the cancel / resume button (the button with inverted triangle enclosed in a circle) hold it for about 5 seconds until the printer self restart.
    ALPUG
    If this will help, please give my answer some ratings!
    Mar 25, 2011 | Computers & Internet
    Canon mp270 error code 5200
    Hello and WelcomeError 5200 is a service error. Follow this solution step by step
    1. With the printer turned on,unplug it
    So go to the Canon Service Center. If you want to get support on Call then
    Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
    Please rate my solution as Four Thumbs if it was helpful. Thank you for using FixYa
    Mar 10, 2011 | Canon Pixma MP270 All-in-One InkJet...
    Will not print. color ink cartridge light keeps
    ..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
    Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
    188 people viewed this question
    old marine
    old marine
    Muntejaya Ginting
    Muntejaya Ginting
    Tareq Bin Mostaq...
    Tareq Bin Mostaq...
