SOURCE: Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
SOURCE: keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
SOURCE: my duo therm ac runs and than when it is almost at
clean the unit tripping on compressor overload
SOURCE: AC Runs for about 10 minute then trips breaker
is your breaker is ok or lose concation is good.if this both is good than cheek his overload.
SOURCE: Dometic Duo-Therm air conditioner: keeps tripping
First clean the condensor with air blower or water pump and clean the filters.If the same problem persists there is a choke up in the refrigeration piping, cut from the discharge side and suction side flush the system with nitrogen, replace the filter drier and choked capillary if it is a capillary system, brace back the discharge and suction piping to the compressor again, leak test with nitrogen, evacuate the system charge refrigerant and start the system.
