Question about Dell Inspiron 530s Desktop Computer
How do you change fontz size on dell computer
Posted by jfhj0548 on
Sumit Gajanan Tambe
    Guru:
  • 219 Answers
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
Posted on Dec 03, 2011
How do I get screen out of shrink size
Carol Taege,
Press control + to increase screen size. Control - to reduce the screen.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 04, 2015 | Dell Computers & Internet
Cant change screen size
If the computer will not let you adjust the screen resolution go to dell's website and search your computer model. Download and install the latest video/graphics driver for your computer. That should fix the issue.
Dec 03, 2012 | Dell Inspiron 640m Notebook
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Mar 30, 2010 | Dell E173FP 17" LCD Monitor
Change the print size
Go to you control panel, open and bring up Display (properties). Click on Appearance and check to see that "Font Size" reads normal. I tried it on my Computer just now and the change to extra large is frightening. :D
Jan 01, 2010 | Dell Computers & Internet
When booting up, my Dell monitor says, "cannot display this video mode", therefore I have no display
you will need to hook a better monitor up to your computer temporarly and make the display mode smaller. once you see you desktop right click go to properties and go to settings change display size to a smaller setting. then hook up your monitor and adjust to the size that suits you
Dec 26, 2009 | Dell E153FP 15" LCD Monitor
When I set the resolution to 1280x1024, the display is wider than the screen and I have to scroll to see the edges. At 1024x768, everything is fine. (Monitor is a Dell 1908FR-BK.)
IF the screen is wider then try to change the settings from the monitor buttons. We change change the screen size , move it , change brightness,etc.
Jul 09, 2009 | Dell UltraSharp 1908FP Monitor
I need to change to size of the print
You have to change the size within the computer software (word?). Use a 11 or 12 size and arial or times as a standard. The mfc prints the job as given by software (with settings given by user).
Nov 27, 2007 | Brother MultiFunction Center MFC-440CN...
Dell Inspiron 530s Desktop Computer   Logo
110 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
