Hello
If you are using a Universal remote control with this set, some button functions won't coincide with the display. If you are using its original remote control, the contacts inside the remote control is dirty or dusty. You have to open the remote control and clean its contact pad and printed circuit touch pad with rectified spirit or medical quality turpentine. Never use petrol of such hard solvents to do this, becuse they will damage the rubber parts of the remote control. If it is a universal remote control doing this will be of no use. It will behave only like this. OK.
thanks, i have done what you said on the remote which is the original. I think its just a setting or maybe how it is cos i can get to the same function via different keys or settings buttons but still the same. I have set up thew source as the manual says but it does say that it mutes the program but i assumed it muted the picture in picture rather than the main picture. i hope im explaining it a little better and thank you for your reply.
If you have cleaned the remote control as I adviced you, and still the problem perists, the signals [infrared pulsed output] from the remote control do not changes according to which it was programmed. Either some rows in the remote control circuit board or columns in it are faulty. If this is the condition, the remote control is damaged and should be replaced. OK.
so its definatley not just a setting ive overlooked cos i can get on to this function from the settings page as well as the pip pap button and also 2 other shoortcut buttons, the remote is in very good nick and i got the tv off a friend, i think he only bought it a couple of years ago but he says hes never even used the function himself, i may try to borrow another remote if i can find one. thank you for all your help and i will try and persist with it. i have nevr had this function before so im not sure wot it should do,, the manual says something about muting the sound but it mutes the sound on the main pictur and i have my outside camera on the pic in pic function but the sound comes from the camera and mutes the tv. am i right in believing that i should have sound on my main pic and mute on the pic in pic. sorry if i sound a bit dumb but this function is new to me and is handy for my cctv outside
i can get to the pip function via menu the buttons on the side of the tv and it still does the same
If so, the memory IC inside the device is faulty. it is an 8 terminal IC cam be located very near to the main system IC. Replace it with same number. Insist on same number as it is the critical part of your device, eventhough it is small; function inside the device is great. It can be bought from most of the electronic spare part shops at your town. OK.
thanks, i'll take a look
OK. Inform me the result..
Just an update to say Ive solved the problem now. It was as I suspedted a setting for flipping the sound sources over. I found it purely by chance. Im just glad thats all it was, thanks for the help.
