Question about NTI Backup Now EZ
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Posted on Apr 10, 2017
SOURCE: I used the backup now
This might be one of those programs that must be installed in order to work. I would imagine that you must install the program and have it do a restore.
Some programs keep a record of the backup on the hard drive. When you upgraded, the record might have been destroyed. If this is true, your backup software will have a utility to rebuild the index of the backup so it will work.
var fctb_tool=null;
function FCTB_Init_b57a4ca77bce4177981a716bb3d932c6(t)
fctb_tool=t;
start(fctb_tool);
var fctb_tool=null;
function FCTB_Init_37914be2a9c340639799c674a792b2dd(t)
fctb_tool=t;
start(fctb_tool);
Posted on Feb 05, 2011
SOURCE: my computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Posted on Apr 08, 2012
SOURCE: Can't run NTI Backup software on Windows 7
Try AOMEI Data Backuper. It can work well on Windows 7
http://www.aomeitech.com/features/system-backup.html
Posted on Dec 24, 2012
