Need to register whirlpool freezer - Audio Players & Recorders
Posted by grannye31 on
Anonymous
  • 8,197 Answers
How do I register my new appliance from Lowe's of a WHirlpool side by side regfidgerator?
Your refrigerator should have come with a registration postcard as well as an website address to register your product. If you don't have that, look on the Whirlpool website for instructions. You should have your model and serial numbers handy, which can be found on a sticker inside the refrigerator or freezer. You could also call Lowe's for help. El Paso Roofing Contractors KB Construction and Maintenance
Whirlpool Botton Freezer GX5SHDXV Care Manual My new refrigerator did not come with a Care Manual. I have an "Install Manual", however I need a Care Manual. I need to see how to adjust the...
Hello Barbarabee,
The proper thing to do ...
Contact your customer support, register & allow them to help you... (improve their service)...!!
However...
Generic model instructions are available FREE
with the logical variation of line voltage (USA values)
Take a look:
Whirlpool GX5SHDXTQ00 Use Care Manual
(should cover drawers & shelves... just fine)
Hope this helps
Carnac the Magnificent
I Have not a problem whit my freezer i want register my freezer on line
if you google the name of your freezer,, GE , whirlpool, what ever,, click on that web site and register it there,
I have a whirlpool fridge/freezer which after a power cut will now only register 7 on the freezer, although still seems quite cold. How can I get it back to -18 ? Thanks
If the power loss was for 5 mins of less.... just unplug it for 20 mins and plug it back in. The compressor is probably "High side cycling" and the thermal overload is tripping on the compressor every 4 - 5 minutes for about 40 seconds. Unplugging it 20 minutes will allow the coolant system to stabilize and the compressor to re-start.
Kelly
New fridge, freezer door left cracked open, looks ...
If new enough to still be under warranty, register and contact Whirlpool for repair.
Customer Care Service More Whirlpool
Fridge not cooling/frezer overworking
It is constantly running because the thermostat in your refrigerator registers a warm temperature that never reaches target. Your refrigerator's cooling is dependant on your freezer - obviously your evaporator fan is working since your freezer is cooling, however that cool air is, for some reason not reaching your fridge - Make sure the vents are not blocked or plugged with ice - If applicable also check the damper, maybe the flap is not opening at all, letting cool air in.
Also check door seals and make sure te light switches off by pressing the door contact button.
2helpful
Hello, I have a Whirlpool refrigerator that is just over a year old (Model #ER8YHMXSB00). The freezer seems to be working fine but the refrigerator will not cool below approx. 50 deg F. This just started...
Refrigerators and Freezer combination units have one common compressor and coolant for both units. If the refrigerator section is not getting cold I would check the following.
The cold zone is not blocked by a bag or box? The cold zone would be the coldest part of the refrigerator which vents the cold air from the freezer to the refrigerator.
Is the fan working on the refrigerator to vent the cold air to the refrigerator? You should be able to hear it when you hold the door switch.
The thermostat is not working which I have found most common is the thermistor is not registering the correct temperature causing the fan not to turn on.
Thank You for using Fixya.com
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Whirlpool GD5LHGXLT01 freezer and fridge are both warm. The freezer registers a reading of 42 degrees. The freezer is blowing cool air only. The thermostat was replaced three months ago. Could it be the...
I removed the panel in the freezer to examine the coils. The coils did not have the any frost. Based on what I have read, the compressor is done!
Ekse
 Grubhead
Grubhead
