The Cuisinart DFP-14BCN has two capacitors, so these steps may be ... Unplug your food processor before starting any disassembly. ... +7 more badges ...
Purchase authorized Cuisinart® replacement parts and accessories for Food Processor Replacement Parts direct ... Discontinued 7 Cup Food Processor (DLC-5).
Missing: capacitor ' Must include: capacitor
PDF
Replacing your faulty capacitor will bring power back to your motor, allowing the blades to spin. The. Cuisinart DFP-14BCN has two capacitors, ...
9 pages
We fixed the same problem with the same Cuisinart DLC-10S, the problem was the white plastic switch on the work bowl - - it was placed above a short clear plastic partition which blocked the switch from pushing the plunger enough to start the motor. It came out of the box that way, bad quality control. I pushed the white plastic switch down over the partition and now the machine works, and the switch can push the pole down the amount needed to start the motor. Very sloppy packaging by Cuisinart. Now the appliance is working, so far. My wife still likes Cuisinart but I'm suggesting she look at other brands next time. The owners manual for this appliance is C*R*A*P and next to useless.
Make sure the work bowl handle is locked in place so that it is facing the front of the processor (same side as the on and off switches).
Make sure the feed tube of the lid is facing toward the back of the processor and that the plastic or metal rod of the pusher sleeve is facing the back of the processor.
Note: this assembly only applies to the Cuisinart DFP-14 series - every Cuisinart has a slightly different assembly for it to turn on.
Sounds like a safety feature working. Unplug. Take apart as if you are going to clean it. Check all parts carefully to see if there is anything broken, like a nub.(Are all parts there?) Put back together, making sure they are fully engaged. Plug in and try. This happened to my food processor and it was a bit of dried food stuck in the bowls sliding track that kept it from clicking fully connected. Hope this helps!
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve. Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good. Put the work bowl on first, with the handle facing the front of the food processor. Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
