Question about Garden
Need to find proper carb needle valve settings for case 444 Kohler
Kelly
  • 3,740 Answers
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Posted on Jul 08, 2011
Testimonial: "First time user....excellent response...time and knowledge a 10 out of ten...gave me the site for reference manual...kudus"
It's leaking fuel out of the carberatetor ,on a 18hr Kohler engine
usually means you have to replace the carb and get the gasket with it. when the needle valve develops a problem they don't intend for you to fix it. this has been my experience.
Jun 24, 2017 | Kohler Electrical Supplies
I have a kohler 25 hp on a simplicity tractor. Turn the key nothing but I can jump across starter the engine starts then shuts itself off in about twenty seconds.new starter and switch
Sounds like you may have two issues..one electrical and one mechanical..
When you say jumping the starter, do you mean the starter solenoid? If you can jump the solenoid and the engine will start, you have a bad solenoid..
The running for twenty seconds is about how long it takes to burn the fuel out of the carb bowl.
The needle and seat need to be cleaned/replaced.. this is the valve that controls the flow of gas into the carb... if its not working properly it will do exactly as you described.. you may need to replace the needle..the seats are sometimes pressed into the carb body and cannot be removed... the needle is rubber coated at the point of contact.. it wears out so the seat does not.. sometimes if the engine has set up for extended time.. cleaning might fix it!!
Jun 06, 2017 | HP Garden
What causes fuel to run out of the carb on a Kohler xt149-0316 engine
Dirt in float bowl, and it causes float not to settle back down.so the needle valve will not shut off fuel flow. The needle valve is on the bottom of float, when it gets enough of fuel the float rises and shuts off fuel until it needs more. God-BLESS! You may have to reset float.
Nov 06, 2015 | Garden
Kohler command 17
  1. Most likely the needle valve in the carburetor is defective. Just this week I had one in the shop doing the same thing. Most of the Kohler engines have a Walbro carburetor. You might look on EBay for the carb kit K10-LMK as it should have what you need. Hope this will help ya.
Jul 19, 2014 | Garden
Walbro Carb flooding 13 hp Kohler
the needle valve in the carb is not seating change the needle valve and seat also check the oil when this happens gas drains into the crankcase if so you will need to change that as well
Jun 28, 2012 | Garden
Have gas getting into the oil 25 hp kohler
With an internally vented carb, if the fuel inlet needle is leaking fuel can enter the cylinder when the engine is stopped through the open inlet valve, you need to replace the needle and check for dirt in the carb
Jun 26, 2012 | Garden
Fuel keeps coming out of the carb
replace the needle valve in the carb the fuel we get now melts the seal off the valve then change the oil
May 20, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Kohler generator set model KT17 that was not run for several years and was full of old gasoline. It would not start at all so I replaced plugs, cleaned fuel pump & filter, then cleaned carb...
Check the genset controller for a fault, low oil psi, no output voltage, overspeed, overcrank / no crank disconnect signal / starter staying engaged, high engine temp.
Jun 26, 2011 | Kohler Electrical Supplies
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
Fuel in the crankcase
Your float valve is sticking - the carb fills up, the fuel runs out through the carb into the engine.
Get a new float valve, until then - turn the fuel off at night.
Jul 01, 2009 | 1988 Suzuki DR 750 S
Garden Logo
631 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
